Persistent black spot on 8MP IMX179 camera image during Zoom calls
Hey everyone — I’m running into a weird issue with my Arducam 8MP IMX179. Whenever I open up Zoom, there’s this dark spot/area showing up in the camera feed. It’s not the background or lighting, it’s definitely something on or in the camera. Here’s a screenshot of what I’m seeing:
black-spot
Anyone seen something like this before? Could it just be dust on the lens?
Quick update — I grabbed an air can and tried blowing off the lens. No luck. The spot is still there, same position, same size. Didn’t budge at all.
Alright, tried wiping the lens down with a microfiber cloth this time. Gave it a pretty thorough cleaning. Still nothing — the black spot is exactly the same. Starting to think it’s not on the lens surface.
Okay so I pulled out a magnifying glass and inspected the lens really closely. The glass is clean — no dust, no smudges, no tiny particles, nothing. Whatever is causing this black spot, it’s definitely not on the outside of the lens. I’m out of ideas here.
Thanks for all the detail, and that screenshot is really helpful. Based on everything you’ve described — the spot not moving after cleaning, the magnifying glass confirming the lens surface is clean — this looks like a small particle of dust that’s sitting directly on the CMOS sensor itself, underneath the sealed lens assembly.
On the IMX179 module, the lens and sensor housing are factory-sealed, so there’s no practical way to get in there and clean the sensor without risking permanent damage to the module. This isn’t something you can fix yourself, unfortunately.
The good news is this kind of internal contamination is covered under Arducam’s warranty. I’ve sent you a private message with the next steps to get a replacement unit sorted out. Check your inbox when you get a chance.
