Ov9281 UC-788 Rev.B not working on Pi5 (bookworm) when "dtoverlay=ov9281" was added "/boot/firmware/config.txt"
    https://www.arducam.com/product/ov9281-mipi-1mp-monochrome-global-shutter-camera-module-m12-mount-lens-raspberry-pi/
    UC-788 Rev.B
    Linux rovi-rpi 6.6.28+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.28-1+rpt1 (2024-04-22) aarch64 GNU/Linux
  1. Instructions you have followed. (link/manual/etc.)
    1MP OV9281 - Arducam Wiki
  2. Problems you were having?
    I can’t access the camera.
  3. The dmesg log from your hardware?
[ 8.081877] pispbe 1000880000.pisp_be: input device node registered as /dev/video20
[ 8.086964] pispbe 1000880000.pisp_be: tdn_input device node registered as /dev/video21
[ 8.087596] pispbe 1000880000.pisp_be: stitch_input device node registered as /dev/video22
[ 8.093289] rp1-cfe 1f00128000.csi: bcm2712_iommu_of_xlate: MMU 1000005280.iommu
[ 8.093688] rp1-cfe 1f00128000.csi: DW dphy Host HW v1.20
[ 8.093704] rp1-cfe 1f00128000.csi: PiSP FE HW v0.1
[ 8.094234] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/ov9281@60
[ 8.096127] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.101494] pispbe 1000880000.pisp_be: hog_output device node registered as /dev/video23
[ 8.102180] pispbe 1000880000.pisp_be: output0 device node registered as /dev/video24
[ 8.105487] rpivid 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[ 8.106978] ov9282 4-0060: fail to write MIPI_CTRL00
[ 8.106992] ov9282 4-0060: failed to power-on the sensor
[ 8.112879] ov9282: probe of 4-0060 failed with error -5
[ 8.124499] pispbe 1000880000.pisp_be: output1 device node registered as /dev/video25
[ 8.124622] pispbe 1000880000.pisp_be: tdn_output device node registered as /dev/video26
[ 8.126401] rpivid 1000800000.codec: Device registered as /dev/video19
[ 8.144528] pispbe 1000880000.pisp_be: stitch_output device node registered as /dev/video27
[ 8.151818] pispbe 1000880000.pisp_be: config device node registered as /dev/video28
[ 8.153324] pispbe 1000880000.pisp_be: Register nodes for group 1
[ 8.159282] pispbe 1000880000.pisp_be: input device node registered as /dev/video29
[ 8.161092] pispbe 1000880000.pisp_be: tdn_input device node registered as /dev/video30
[ 8.190737] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.195040] pispbe 1000880000.pisp_be: stitch_input device node registered as /dev/video31
[ 8.199768] Loaded X.509 cert ‘[email protected]: 577e021cb980e0e820821ba7b54b4961b8b4fadf’
[ 8.200092] Loaded X.509 cert ‘[email protected]: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328’
[ 8.200417] Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 8.200727] Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
[ 8.246582] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 8.250157] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.250383] usbcore: registered new interface driver brcmfmac
[ 8.292825] alsactl[468]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 8.302258] pispbe 1000880000.pisp_be: hog_output device node registered as /dev/video32
[ 8.302349] pispbe 1000880000.pisp_be: output0 device node registered as /dev/video33
[ 8.302410] pispbe 1000880000.pisp_be: output1 device node registered as /dev/video34
[ 8.302472] pispbe 1000880000.pisp_be: tdn_output device node registered as /dev/video35
[ 8.302525] pispbe 1000880000.pisp_be: stitch_output device node registered as /dev/video36
[ 8.302567] pispbe 1000880000.pisp_be: config device node registered as /dev/video37
  2. What help do you need?
    Same camera module works outof box on CM4, Pi4 module.
    On the website, it says it works on Pi5.
    What are steps I need to take to use ov9281 camera on Pi5 (bookworm) other than adding “dtoverlay=ov9281”?
This camera module does work on Pi 5.
As we all know, Pi 5 has two camera ports, aka CAM 0 and CAM 1. If you add “dtoverlay=ov9281” in the config.txt file, you should connect this camera module to the CAM 1 port on your Raspberry Pi 5.
Looking forward to your feedback.
