OV9281 not seen
robotshop.com
B0224 & B0225
Raspberry Pi 4B
/cameras-for-raspberry-pi/migrated/ov9281-1mp-global-shutter-raspberrypi-camera & /cameras-for-raspberry-pi/mipi-camera-modules/camera-userland-driver-sdk-and-examples/
No both doesn’t work
No connection at all.
Cables check many times.
pi@raspberrypi:~ $ ./MIPI_Camera/RPI/utils/camera_i2c
setting GPIO for board revsion: b03111
Raspberry Pi3B / Pi3B+ / 3A / 4B(1G/2G/4G)
./MIPI_Camera/RPI/utils/camera_i2c: 137: ./MIPI_Camera/RPI/utils/camera_i2c: ./rpi3-gpiovirtbuf: not found
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
pi@raspberrypi:~ $ ~/MIPI_Camera/RPI/arducamstill
Open camera...
Hardware platform: b03111
init camera status = 4100
Read and aplly all documentation and forum topics I found
Make them work
pi@raspberrypi:~/MIPI_Camera/RPI/utils $ ./camera_i2c
Set state of 133 to 1
Thanks for your contacting us.
Don’t worry and I will try my best to help you.
It seems that your camera’s hardware connection is abnormal. Please check the hardware connection in detail. What’s more, do you have extra cable line?
Solved it is working now. Thank you.
I changed the raspberry pi (but keep the sd card). All of the B0225, B0224 and the official camera v2.1 didn’t connect.
Great to hear that. Free free to let me know if you need more help.
