Hello ArduCam Support Team,
I am using a UC-788 RevB camera board with the OV9281 sensor on Jetson Orin Nano (JetPack 6.2 / L4T 36.4.3) with the Jetvariety driver.
I followed the instruction and installed driver
arducam-nvidia-l4t-kernel-t234-nx-5.15.148-tegra-36.4.3-20250124133829_arm64.debusinginstall_full.sh
I have installed the latestarducam-nvidia-l4t-kernelpackage and see thearducam_csi2module loaded. However, there is noov9281.dtbooverlay in/boot/arducam/dts/. -
As a result, the camera is not powered up and not visible on I²C (
i2cdetectshows no device), and dmesg logs display:
jetson@jetson:~$ sudo dmesg | grep arducam
[ 10.956747] arducam-csi2: arducam_read: Reading register 0x103 failed
[ 10.956756] arducam-csi2 9-000c: probe failed
[ 10.956780] arducam-csi2 9-000c: Failed to setup board.
[ 11.000211] arducam-csi2: arducam_read: Reading register 0x103 failed
[ 11.000222] arducam-csi2 10-000c: probe failed
[ 11.000245] arducam-csi2 10-000c: Failed to setup board.
- Here is the current DTO exported to text for more info.
- What could you recommend to do? Or maybe you could possibly provide the correct DTS/DTBO overlay for UC-788 RevB (OV9281) on Jetson Orin Nano?
Or any additional configuration steps required for Jetvariety with UC-788 RevB ?
Thank you for your support!
Best regards,
Ben
