OV9281 gstreamer not working
What is the gstream pipeline of open cv gstream pipeline to run the ov9281 B0223
https://www.arducam.com/arducam-ov9281-mipi-1mp-monochrome-global-shutter-ir-camera-module-for-jetson-board.html
ov2311 is working but not ov9281 on gstreamer
gst-launch-1.0 -v v4l2src device=/dev/video0 !
“video/x-raw, format=(string)GRAY8, width=(int)1280, height=(int)720, framerate=80/1” !
videoconvert ! xvimagesink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
WARNING: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Signal lost
Additional debug info:
…/sys/v4l2/gstv4l2src.c(556): gst_v4l2src_query_preferred_size (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
No input source was detected - video frames invalid
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, format=(string)GRAY8, width=(int)1280, height=(int)720, framerate=(fraction)80/1, interlace-mode=(string)progressive, colorimetry=(string)1:4:7:1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)GRAY8, width=(int)1280, height=(int)720, framerate=(fraction)80/1, interlace-mode=(string)progressive, colorimetry=(string)1:4:7:1
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)80/1, interlace-mode=(string)progressive, format=(string)YUY2, colorimetry=(string)2:3:7:1
/GstPipeline:pipeline0/GstXvImageSink:xvimagesink0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)80/1, interlace-mode=(string)progressive, format=(string)YUY2, colorimetry=(string)2:3:7:1
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, format=(string)GRAY8, width=(int)1280, height=(int)720, framerate=(fraction)80/1, interlace-mode=(string)progressive, colorimetry=(string)1:4:7:1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)GRAY8, width=(int)1280, height=(int)720, framerate=(fraction)80/1, interlace-mode=(string)progressive, colorimetry=(string)1:4:7:1
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:09.220191610
Setting pipeline to NULL .
Hi there,
I’ve replied to you via email. Please check your inbox.
Hi, I have the same issue. How to solve?
Hi @leohaijun
Can you get the stream up and running after following the steps in the link below?
https://docs.arducam.com/Nvidia-Jetson-Camera/Jetvariety-Camera/Quick-Start-Guide/#diagram-nvidia-jetson-orin-nx
Especially with the arducam_displayer.py program, are you able to access the camera with it?
