UCTRONICS
UC599 - Arducam OV9281 1MP Global Shutter NoIR Mono Camera with 130deg M12 Mount for Raspberry Pi and Arducam OV9281 1MP Mono Global Shutter Camera with 130deg 850nm Only M12 Mount
Raspberrypi4
https://www.arducam.com/docs/cameras-for-raspberry-pi/migrated/ov9281-1mp-global-shutter-raspberrypi-camera/
quit working
I followed the below link procedure
When i run the arducamstill, the below error is coming
Open camera…
init camera status = 4100
When i open with OPENCV camera video is coming but frame rate is too slow and i unable to set and get the frame rate and other settings.
yes, i followed some posts from arducam forum and i tried arducam userland MIPI driver
I need to open the camera alteast 30FPS and able to control the camera properties
