ArduCam
B0483
Raspberry Pi
Instructions you have followed. (link/manual/etc.) ArduCam Docs Page
5. Problems you were having?
Sometimes the images are coming out with a blue colour or layer. This happens randomly. It is consistent for both cameras attached to the same Raspberry Pi 5.
I have two cameras attached to the RPi 5. Both are taking photos together (at the same time). Sometimes they both give a blue image. Sometimes they give a normal image.
The camera is taking photos every 1 minute. So I have plenty of examples.
This will output an “arducam-bug-report.txt” file in the current directory. Please put this file on the google drive or other place so that I can check it.
I need information of your Raspberry Pi to reproduce the problem on our side.
Hi Henri,
It is like a “lip-service”, hhh. But actually, I’m gona reproduce the problem this afternoon.
Just update the status and tell you that I do not forget this case.
also i have to mention that in my case the fluorescent lightbulb in the ceiling is creating interference pattern on the images so if u are unable to reproduce the lighting might be the issue.
But the arducam cameras get the interference pattern. I dont consider it a bug but a feature. Here u can see the interference pattern lines on picture with arducam 64mp (:
This happens with max res 9152x6944 (i scaled down the uploaded image) but for example i tested it with 1280x720 it does not happen. Something related to frequencies and exposure time.
I just confirmed by testing that the fix for the blue images is to turn off lighting in the office. The product im developing will have LED light source anyways so i dont need to change the office lighting solution.
Some more info on the flourescent lighting interference pattern: https://xdaforums.com/t/interference-pattern-on-camera-with-fluorescent-lighting.1231173/
