OV5647 camera preview unavailable on Raspberry Pi B Bullseye - libcamera no cameras available
Hi, I’m having trouble with my Arducam OV5647 (B0033) on a Raspberry Pi B running Bullseye (version 11). The preview window is unavailable and libcamera says no cameras available. I’ve already tried enabling Glamor in config, changing dtoverlay to ov5647, and even reformatted the Pi with a fresh image, but nothing changed. Here’s the log:
[0:08:27.059676931] [1032] INFO Camera camera_manager.cpp:299 libcamera v0.0.4+22-923f5d70
Any ideas?
Thanks for the details. Since libcamera reports no cameras available, let’s grab a diagnostic report to see what the system is actually seeing. Please reboot your device, then run these commands:
That will generate an arducam-bug-report.txt file in the current directory. Send that file over and we’ll take a look.
Done, I ran the tool and it generated the file. I’ve sent the arducam-bug-report.txt over. What should I check next?
Thanks, I received the report. While I review it, please go through the official Raspberry Pi camera software configuration guide here:
https://www.raspberrypi.com/documentation/computers/camera_software.html
Confirm that your camera software setup matches the steps in that documentation.
Still no luck after going through the docs. The camera is still not detected and I’m getting the same “no cameras available” error. I’ve attached a new bug report:
Thanks. At this point I’d like to rule out a physical connection issue. Could you post photos of both ends of the hardware connection — the camera end and the Raspberry Pi end?
Sure, here are photos of the connection:
Thanks for the photos. Do you happen to have another white flex cable on your side? If so, please swap the cable connecting the camera to the Raspberry Pi with that one and see if the camera gets detected.
I tried two different flex cables and it’s still not working. Same error, camera still not detected.
Thanks for testing that. To recap what we’ve ruled out so far: we’ve confirmed the error is “no cameras available” in libcamera v0.0.4+22-923f5d70, tried a fresh Bullseye image, enabled Glamor, set dtoverlay=ov5647, followed the official camera software docs, inspected the physical connection, and swapped two flex cables. Since the camera is still not detected, the remaining suspects are the camera module itself or the Pi’s camera interface. I’ll follow up with the next diagnostic steps.
