Hey, hoping someone can help me out. I bought an Arducam OV5647 camera for my Raspberry Pi 4 (8GB, 64-bit Raspios Bullseye) and I have NEVER gotten it to work. I followed the paper that came with the camera. Every time I try to use it I get:
*** no cameras available ***
I’ve tried it on 4 different Pis now and all of them say the same thing - not detected. I’ve tried everything on that paper and some stuff I found online. Totally stuck here.
Thanks, that’s actually useful. Two things stand out.
vcgencmd get_camera is a legacy command. It’s built for the old raspistill/raspivid stack. On Bullseye with a Pi 4 you should be using the libcamera apps (libcamera-still, libcamera-hello), so that output being 0 doesn’t mean much on its own.
The libcamera-still log is more telling. It actually DID register the sensor at /base/soc/i2c0mux/i2c@1/ov5647@36 on Unicam /dev/media2 and ISP /dev/media0 - so the sensor was detected. But right after, it says ‘Unicam has timed out’ and no frames come through.
That usually means either a cable/connector problem or a driver conflict. Can you paste your /boot/config.txt? I want to check what overlays are set.
That’s the problem. dtoverlay=imx519 is for a completely different sensor (IMX519), not your OV5647. That leftover overlay will conflict and stop the OV5647 driver from doing its job.
Do this:
sudo nano /boot/config.txt
Find the line dtoverlay=imx519 and comment it out (put a # in front of it).
Ok. I grabbed the same OV5647 and tested it on a Pi4B and a Pi 3, including on the 64-bit Bullseye image, and it works normally on all of them. So the driver/config path is fine when the hardware cooperates.
Given what we’re seeing - the sensor registers (ov5647@36 shows up) but then ‘Unicam has timed out’ and no frames ever come through, even after reseating the cable and re-burning from scratch - this really points at a problem with the camera module itself. So we’ll arrange a replacement for you. I’ve sent you the details through private message - please check there.
Appreciate it. Quick question before that - could I upgrade to something higher res instead? I was looking at the 64MP / 65MP cameras, is that an option?
The OV5647 was detected on the bus (registered as /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam /dev/media2, ISP /dev/media0) but the data path failed - ‘Unicam has timed out’, ‘no cameras available’. That stayed the same after reseating the sensor connector and fully re-burning the image, which is why we’re treating it as a faulty module and arranging a replacement.
On Bullseye/Pi4 the legacy vcgencmd get_camera (and raspistill/raspivid) tooling isn’t meaningful - use the libcamera apps like libcamera-still and libcamera-hello instead.
A leftover dtoverlay=imx519 in /boot/config.txt will conflict with an OV5647. Comment it out, then add dtoverlay=ov5647,clock-frequency=25000000 under the [all] section.
‘Camera sensor does not support test pattern modes’ together with ‘Unicam has timed out’ / ‘no cameras available’ means the sensor is detected but the data path fails - reseat the connector/cable first, and replace if it still won’t stream.
For order, return, or upgrade questions (including the 64MP/65MP option), email [email protected] and they’ll sort it out with you.
