OV2640 STROBE pin and V/T pins on ArduCAM 2MP Mini Plus for flash sync?
Hey everyone, I’m trying to set up an external LED flash that fires in sync with the camera capture on my ArduCAM 2MP Mini Plus module. I’ve been digging through the OV2640 sensor datasheet and noticed it has a STROBE pin that’s supposed to do exactly this — pulse during image exposure. Problem is, I can’t seem to find any STROBE pin labeled on the ArduCAM board itself. Also, there are two pins on the side labeled V and T — anyone know what those actually do? Could one of them be the STROBE signal? Any help appreciated, I’m a bit stuck.
Good question. First, just a small correction — the sensor on the ArduCAM 2MP Mini Plus is actually an OV2642, not the OV2640. They’re quite similar but it’s worth noting for datasheet reference. You’re right that the OV2642 does have a STROBE pin on the sensor itself, and it’s designed precisely for what you’re describing — synchronizing an external LED flash during image capture. Now, whether that pin is actually brought out on the ArduCAM board is a different matter. Let me check the board layout and get back to you. As for the V and T pins, I’ll cover those too once I’ve confirmed everything.
Ah, OV2642 — my mistake, thanks for catching that. And yeah, please do check the board. I’ve been staring at this thing with a magnifier and I just don’t see any extra broken-out pins besides those V and T ones. Hoping there’s a test point or something I’m missing.
Okay, I’ve gone through the ArduCAM 2MP Mini Plus board design. Unfortunately, the news isn’t great — the STROBE pin from the OV2642 sensor is not routed to any external connection on this board. It’s simply not exposed. So there’s no header pin, no test pad, nothing you can solder to for that signal. As for the V and T pins: the V pin is Vcc — it’s a power pin. The T pin is a trigger pin, but it’s connected to the onboard CPLD, not to the image sensor. It’s used for triggering the capture from the CPLD side and has nothing to do with the sensor’s STROBE output. So neither of these pins can serve as a flash sync signal.
That’s disappointing, but thanks for the clear explanation. So just to make sure I’m not misunderstanding — the T pin triggers the CPLD to initiate a frame capture, it’s an input, not something that pulses in sync with exposure timing? There’s really no hacky way to repurpose it?
Exactly right — the T pin is an input to the CPLD, not an output from the sensor. It tells the CPLD when to start a capture, so its timing is completely unrelated to the sensor’s internal exposure window. There’s no way to repurpose it as a flash sync output, unfortunately. And since the STROBE pin from the OV2642 isn’t broken out anywhere on the PCB, there’s just no access point to tap into that signal. It’s a hardware limitation of this particular board design — the STROBE functionality exists on the sensor silicon but was never routed out.
So to summarize: external LED flash synchronization via the sensor’s STROBE signal is not possible on the ArduCAM 2MP Mini Plus. There’s no workaround I can suggest on this board — the signal simply isn’t accessible. If flash sync is critical for your project, you’d likely need to look at a different camera module that explicitly exposes the STROBE pin, or explore external timing solutions (like an MCU-timed flash triggered by your capture routine), though that won’t be as precise as the sensor’s native STROBE output which is aligned to the actual exposure window. Sorry I don’t have better news on this one.
