As requested, here is a new thread about the compatibility and configuration of OV2311 with Raspberry Pi5 running under Bookworm.
2MP Global Shutter OV2311 Mono Camera Modules Pivariety (NoIR), compatible with Raspberry Pi ISP and Gstreamer Plugin-Arducam -
Model number of the product(s).
SKU: B0381 - Arducam PiVariety 2MP Global Shutter OV2311 Mono Camera Modules -
Raspberry Pi 5 -
No instructions -
Problems you were having.
Can’t access the camera with libcamera nor V4L2 tools
user@pi5:~ $ libcamera-hello -t 0 --camera 1
[0:07:42.733471724] [2846] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+118-563cd78e
[0:07:42.747674097] [2849] INFO RPI pisp.cpp:653 libpisp version v1.0.2 fa44a258644a 22-11-2023 (21:59:22)
[0:07:42.761585654] [2849] WARN CameraSensorProperties camera_sensor_properties.cpp:261 No static properties available for 'arducam-pivariety'
[0:07:42.761602098] [2849] WARN CameraSensorProperties camera_sensor_properties.cpp:263 Please consider updating the camera sensor properties database
[0:07:42.769951691] [2849] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety_mono.json' not found for IPA module 'rpi/pisp'
[0:07:42.774628741] [2849] ERROR IPARPI ipa_base.cpp:124 Could not create camera helper for arducam-pivariety
[0:07:42.774645482] [2849] ERROR RPI pipeline_base.cpp:802 Failed to load a suitable IPA library
[0:07:42.774654390] [2849] ERROR RPI pisp.cpp:880 Failed to register camera arducam-pivariety 4-000c: -22
libEGL warning: DRI3: failed to query the version
X Error of failed request: BadRequest (invalid request code or no such operation)
Major opcode of failed request: 155 ()
Minor opcode of failed request: 1
Serial number of failed request: 16
Current serial number in output stream: 16
- System related information:
user@pi5:~ $ uname -a
Linux pi5 6.1.0-rpi7-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (2023-11-24) aarch64 GNU/Linux
user@pi5:~ $ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
user@pi5:~ $ cat /proc/meminfo
MemTotal: 8247024 kB
MemFree: 7009792 kB
MemAvailable: 7599280 kB
Buffers: 29424 kB
Cached: 702128 kB
SwapCached: 0 kB
Active: 649904 kB
Inactive: 350512 kB
Active(anon): 343328 kB
Inactive(anon): 9312 kB
Active(file): 306576 kB
Inactive(file): 341200 kB
Unevictable: 58640 kB
Mlocked: 0 kB
SwapTotal: 102384 kB
SwapFree: 102384 kB
Zswap: 0 kB
Zswapped: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 327696 kB
Mapped: 216576 kB
Shmem: 83776 kB
KReclaimable: 30592 kB
Slab: 65904 kB
SReclaimable: 30592 kB
SUnreclaim: 35312 kB
KernelStack: 4384 kB
PageTables: 10528 kB
SecPageTables: 0 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 4225888 kB
Committed_AS: 1687504 kB
VmallocTotal: 68182212608 kB
VmallocUsed: 19792 kB
VmallocChunk: 0 kB
Percpu: 1280 kB
CmaTotal: 327680 kB
CmaFree: 311200 kB
user@pi5:~ $ cat /boot/config.txt
# http://rptl.io/configtxt
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
dtoverlay=arducam-pivariety,cam1
- Troubleshooting attempts you’ve made.
user@pi5:~ $ dmesg | grep -E "ov2311|arducam"
[ 2.975639] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/arducam_pivariety@c
[ 2.990065] arducam-pivariety 4-000c: firmware version: 0x10002
[ 3.219722] rp1-cfe 1f00128000.csi: Using sensor arducam-pivariety 4-000c for capture
user@pi5:~ $ v4l2-ctl --list-devices
pispbe (platform:1000880000.pisp_be):
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video24
/dev/video25
/dev/video26
/dev/video27
/dev/video28
/dev/video29
/dev/video30
/dev/video31
/dev/video32
/dev/video33
/dev/video34
/dev/video35
/dev/video36
/dev/video37
/dev/media1
/dev/media3
rp1-cfe (platform:1f00128000.csi):
/dev/video0
/dev/video1
/dev/video2
/dev/video3
/dev/video4
/dev/video5
/dev/video6
/dev/video7
/dev/media0
rpivid (platform:rpivid):
/dev/video19
/dev/media2
- What help do you need?
Is the ov2311 camera module from Arducam (B0381, uctronics) compatible with Pi5 and Bookworm?
Or should it work and my configuration is faulty?
Thanks
