OV2311 exposure control
Scorpion Vision Ltd
OV2311
Raspberry Pi Buster Raspberry Pi 4 8G
https://www.arducam.com/docs/arducam-obisp-mipi-camera-module/3-use-on-raspberry-pi/3-0-emergent-temporary-driver-for-the-lastest-rpi-2020-12-02-update/
Working with issue described below.
I am able to grab images with fswebcam, but they are over exposed even in dark conditions. If I view the image in vlc (vlc v4l2:///dev/video2) I can adjust the exposure, but even at the minimum value it is too high (even in cloudy Scotland!).
The image shows the camera with gain and exposure set to minimum values in fairly low light conditions but the image is already starting to be over exposed.
are there other controls available (apart from exposure and gain) that I need to use.
Please attach me your hardware connetion diagram. For the single OV2311, we advise you use our MIPI_Camera driver instead of V4l2 driver.
Using V4l2 driver, you should have pivariety board. I want to ensure your hardware status.
Hi, thanks for your reply
I’m using the stereo camera;
https://www.arducam.com/product/arducam-2mp-stereo-camera-for-raspberry-pi-nvidia-jetson-nano-xavier-nx-dual-ov2311-monochrome-global-shutter-camera-module/
We have tested it and It seems nonaml. I have attached a operation demo for you.
