Hey everyone, I’m running into a frustrating issue with my camera setup. I’ve got /dev/video0 showing up after boot, but the video stream is completely black no matter what I try. Has anyone else seen this?
I have a feeling it’s related to the overlay file — the default one probably doesn’t match the pin mapping on my carrier board. Maybe the CSI pins or the GPIO reset/power-down lines are mapped differently. Anyone know what I should be looking at?
Could you share some details about your hardware and software setup? That’ll help narrow things down — which Jetson module, carrier board, camera model, and JetPack version are you working with?
I installed the arducam-nvidia-l4t-kernel package and applied the tegra234-p3767-camera-p3768-arducam-dual.dtbo overlay. That’s the only overlay that actually gets /dev/video0 to show up. Without it, no video device at all. But even though the device node is there, the stream is just black.
That’s helpful. So just to confirm — with other overlays you get no /dev/video0 at all? And with the dual overlay it appears but gives you nothing but black frames?
Can you run v4l2-ctl --list-devices and also try capturing a raw frame with v4l2-ctl --stream-mmap --stream-count=1 --stream-to=test.raw and then check the file size with ls -la test.raw? That’ll tell us if any data is actually coming through at all.
Zero bytes confirms the sensor isn’t actually streaming any data. The driver is loaded and the device node is created, but the pipeline between the sensor and the ISP isn’t working.
This is actually a known situation with third-party carrier boards. The overlay you’re using — tegra234-p3767-camera-p3768-arducam-dual.dtbo — is designed specifically for the official Nvidia Jetson carrier board (the p3768 baseboard). The Seeed A603 has its own CSI connector pin mapping and GPIO layout that’s different from the reference design.
So what’s likely happening: the overlay is configuring the camera sensor’s I2C address and the Tegra CSI/VI ports based on the official board’s routing, but on your A603 the reset GPIO, power-down GPIO, or even the CSI lane mapping may be completely different. The sensor driver probes successfully over I2C (hence /dev/video0 appears), but the sensor never actually starts streaming because the reset/power pins aren’t being toggled correctly from the perspective of your board’s physical layout.
That makes a lot of sense — I was worried this was the case when I started seeing the mismatch between the overlay names (p3768) and my carrier board.
So what are my options here? Can you provide either:
a) A dedicated .dtbo overlay file that’s compatible with the Seeed A603 and the OV2311, or
b) The correct device tree source (.dts) modifications so I can rebuild a working overlay myself?
I’m comfortable editing device tree sources and recompiling, I just need to know what to change.
I’ve looked into this and I need to be upfront — we don’t have a ready-made overlay for the Seeed A603 carrier board, and unfortunately we can’t create one specifically for it.
Our camera driver development and overlay files are built and tested against the official Nvidia Jetson carrier boards. The pin mapping, GPIO assignments, and CSI lane routing on the A603 are Seeed’s design and we don’t have the reference schematics or a test board to validate against.
What I can do is send you a patch file (via private message) for the official carrier board setup. It’ll contain the reference device tree modifications for the OV2311 on the official p3768 baseboard. You can use that as a starting point to port the changes to match the A603’s layout.
The key areas you’ll need to adapt in the device tree are:
CSI lane mapping — which CSI port and which lanes on the Orin NX the A603 routes the camera connector to
GPIO assignments — specifically the reset-gpios, pwdn-gpios, and any other control lines defined in the camera node
I2C bus — which I2C bus the camera sits on, and the correct I2C address
Clock source — whether the A603 provides an external XCLK or relies on the Tegra’s CAM_MCLK
You’ll need to cross-reference the Seeed A603 schematics (or pinout documentation) with our reference patch. Check your private messages — I’ve sent the patch file there.
Got it, thanks for the honest answer and the reference patch. I’ll dig into the A603 schematics and compare against what you sent.
For anyone else who stumbles on this thread in the future — if you’re using a third-party carrier board with Arducam cameras and get /dev/video0 but a black stream, check your GPIO and CSI pin mapping against the overlay. The device node showing up just means I2C communication works; the actual video pipeline depends on the physical routing matching what the overlay describes.
I’ll post back here once I’ve got the port working in case it helps someone else.
That’s a great summary. Just to add one more thing — when you’re porting the device tree, pay special attention to the mode and phy_mode properties in the CSI endpoint nodes. On the official board we use continuous clock mode, but if the A603 routes things differently you may need to adjust this.
Also, a useful debugging step once you’ve made your changes: check sudo media-ctl -p to see the full media pipeline topology. If any link is disabled or the pad format doesn’t match between entities, that can silently cause the black stream even when /dev/video0 is present.
Good luck with the port, and definitely let us know how it goes.
