OV2311 Camera Fails to Start on reComputer J3011 (Third-Party Board)
Hey everyone, hoping someone here can point me in the right direction. I’m trying to get an Arducam OV2311 camera working on my reComputer J3011 board from Seeed Studio (link: https://www.seeedstudio.com/reComputer-J3011-p-5590.html).
I followed the Arducam Jetvariety Camera Quick Start Guide step by step: Quick Start Guide - Arducam Wiki
But when I try to start the camera I get an error. Here’s what I’m seeing:
error screenshot
Environment details:
  • Camera: Arducam OV2311
  • Board: reComputer J3011 (Seeed Studio)
I realize the J3011 is a third-party carrier board and it may not be officially supported, but I’m hoping someone has run into this before and found a workaround. Any ideas?
Thanks for the detailed report and the screenshot — that helps a lot.
The short answer is that the reComputer J3011 is indeed a third-party carrier board, and this is where the problem lies. Arducam CSI cameras are validated specifically against official Nvidia Jetson Developer Kits. Third-party carrier boards like the Seeed Studio J3011 often have different pin configurations and signal routing from the official Nvidia reference design, and these hardware-level differences are exactly what can cause the camera to fail to initialize.
So the error you’re seeing isn’t necessarily a driver bug or a bad camera — it’s very likely a hardware compatibility issue between the OV2311 and the J3011’s CSI interface.
Before we go further down the rabbit hole, there’s one important test I’d recommend to narrow this down:
Do you have access to an official Nvidia Jetson Developer Kit (like the Jetson Orin Nano Dev Kit or similar)? If so, try the OV2311 on that board using the same driver installation steps.
  • If the camera works on the official dev kit, then the OV2311 itself is fine and the issue is specifically with the reComputer J3011’s CSI implementation.
  • If the camera also fails on the official kit, then it could be a driver or camera hardware issue and we can dig into that separately.
Let me know what you find — that’ll tell us a lot about next steps.
Appreciate the honest assessment. Unfortunately, I don’t have an official Nvidia Jetson Developer Kit on hand to run that isolation test, so I’m kind of stuck on the J3011 for now.
Given that the reComputer J3011 isn’t compatible with the Arducam CSI cameras, is there any alternative camera you’d recommend that would work on this board? My requirements are:
  • Global shutter
  • Monochrome
  • Needs to actually work with a third-party carrier board like the J3011
I know my options might be limited here, but I’d rather not buy another board just to run the camera. Any suggestions?
That’s a fair question, and I want to give you a clear picture of why this is tricky before I suggest a path forward.
The core issue isn’t specific to the OV2311 — it applies to CSI cameras in general. Any CSI camera (Arducam or otherwise) relies on board-specific support packages. The CSI interface needs proper signal routing, correct pin mapping, and a BSP (Board Support Package) that knows how to talk to the camera over those physical lanes. Third-party carrier boards don’t always replicate the official Nvidia CSI layout faithfully, and even when they do, the BSP may not include the right camera device tree entries or clock configurations. That’s why we can’t guarantee any CSI camera will work on a third-party board like the J3011.
Here’s what I’d recommend instead: look at UVC (USB Video Class) camera modules.
UVC cameras connect over USB and use standard USB drivers that are already built into the kernel — no special BSP modifications, no CSI pin mapping headaches, no device tree tinkering. They’re essentially plug-and-play. Arducam has UVC camera modules in their lineup, and these will work on pretty much any Jetson-based system including third-party carrier boards like the J3011, because USB is standardized across all of them.
You’d want to check the Arducam UVC offerings to see if there’s a global shutter monochrome model that fits your application. Switching from CSI to UVC would side-step the whole third-party carrier board compatibility problem entirely. That’s honestly the most reliable path for anyone running a custom or third-party carrier board where CSI support can’t be guaranteed.
