UCTRONICS -
Model number of the product(s).
B0353 -
Orin NX 16GB -
Jetvariety-Camera/Quick-Start-Guide/ on Arducam -
Problems you were having.
[ WARN:[email protected]] global cap_v4l.cpp:982 open VIDEOIO(V4L2:/dev/video0): can’t open camera by index
[ WARN:[email protected]] global cap.cpp:342 open VIDEOIO(V4L2): backend is generally available but can’t be used to capture by index
File “/usr/local/lib/python3.8/dist-packages/jtop/jtop.py”, line 1113, in start
self._broadcaster.connect()
File “/usr/lib/python3.8/multiprocessing/managers.py”, line 548, in connect
conn = Client(self._address, authkey=self._authkey)
File “/usr/lib/python3.8/multiprocessing/connection.py”, line 502, in Client
c = SocketClient(address)
File “/usr/lib/python3.8/multiprocessing/connection.py”, line 630, in SocketClient
s.connect(address)
PermissionError: [Errno 13] Permission denied
During handling of the above exception, another exception occurred:
File “arducam_displayer.py”, line 135, in
arducam_utils = ArducamUtils(args.device)
File “/home/ubu/MIPI_Camera/Jetson/Jetvariety/example/utils.py”, line 131, in init
with jtop() as jetson:
File “/usr/local/lib/python3.8/dist-packages/jtop/jtop.py”, line 1277, in enter
self.start()
File “/usr/local/lib/python3.8/dist-packages/jtop/jtop.py”, line 1129, in start
raise JtopException(“I can’t access jtop.service.\nPlease logout or reboot this board.”)
jtop.core.exceptions.JtopException: I can’t access jtop.service.
- The dmesg log from your hardware.
ubu@ubu-desktop:~/MIPI_Camera/Jetson/Jetvariety/example$ cat /var/log/dmesg | grep -E "arducam"
[ 0.000000] kernel: Linux version 5.10.104-tegra (arducam_006@arducam-server-006) (aarch64-linux-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Fri Jul 21 17:08:15 CST 2023
Troubleshooting attempts you’ve made.
Requirescv2.VideoCapture(0)to be set to-1, but Line 128 of arducam_displayer.py
iscap = cv2.VideoCapture(args.device, cv2.CAP_V4L2)
59371075/opencv-error-cant-open-camera-through-video-capture on StackOverflow. -
Resolve the issue, and get camera working.
