Local online store (tokopedia.com)
USB Shield2 Rev E and IMX 219 board B102
Raspberry Pi
installing arducam config parser and install libusb version 1.0.24
Worked on Windows
Hi there,
I already trying python script for streaming video for my board, and it can streamed image, but when I run on raspberry, it always failed to open with return value 65281.
I am using Python 3.7.3 on Raspberry Pi.
Could you give me clue what the problem is.
Thank you
Here is additional information for what I’ve done :
I tried the python demos on Windows and it worked
-On my raspi (4B), the command ArduCam_scan could detect the camera (found device).(I already installed arducam config parser, latest libusb, have opencv (ver 4.2.0)
On ArduCam_open and ArduCam_autoopen, always return 65281 (USB_CAMERA_USB_CREATE_ERROR)
Between scanning and opening, already have delay > 2s
Not sure about the arducamSDK.so, I trying using ArducamSDK.cpython-37m-arm-linux-gnueabihf.so, with the same result.
I am using IMX219_MIPI_2Lane_RAW10_8b_640x480_30fps.cfg configuration file
Please advise, is there any other thing I could try.
Sorry to reply to you so late, there is a problem with our forum service system, it has been fixed now, has your problem been solved? Please feel free to let me know if you need more help.
