Hi all, I’m stuck getting my stereo camera pair to work — only one of the two cameras seems to be working at all. I need both of them for stereo imaging.
I was thinking of trying a legacy version of Pi OS with the old raspi-still package. Would that work, or is there another way to get stereo images from this setup?
Thanks for the details. Before we go down the legacy OS path, can you clarify what “only one camera is working” actually looks like? For example, does one camera turn dark when you preview, or does it not appear at all?
That guide note about the latest software supporting only one camera at a time is important, but let’s pin down the exact symptom first.
To clarify: the preview window only ever shows one of the two cameras. I can’t get the other one to appear at all.
I also tried the camera switching commands from the docs. Running:
i2cset -y 0 0x24 0x24 0x00
plus a few variants of the same command doesn’t change which camera shows up. Nothing changes.
Thanks for the videos and photos. Let’s try a swap test to isolate where the fault is: exchange the positions of the two cameras — swap which camera is plugged into which port on the HAT.
If the problem follows the camera module (the same camera stays invisible after swapping), then it’s a module fault. If the problem stays with the same connector/port on the HAT, then the HAT board is the likely culprit.
We haven’t pinned down the root cause yet, and the i2cset switching not working is unusual, so this swap test should tell us a lot. Let me know what you find.
