No support found for ArduCAM Mini 2MP Plus with ESP32D
Hi everyone, I’m trying to get an ArduCAM Mini 2MP Plus working with an ESP32D board, but I can’t seem to find any support for this camera/module combination anywhere. I’ve searched through the ArduCAM GitHub and a bunch of other places and there’s just nothing. Has anyone managed to get this combo running?
Thanks for posting. To help narrow this down, could you share a bit more about your setup? Specifically which ESP32D board you’re using, and whether you have any code running yet or any logs/errors from the serial output.
Sure. The hardware is the ArduCAM Mini 2MP Plus and an ESP32D. As for code, I don’t have anything yet - I couldn’t find any example for this camera on the ESP32D, so I haven’t been able to try anything. No logs either since nothing has run.
Right, that matches what I’m seeing on my end too. There’s no off-the-shelf example code available from ArduCAM for the ESP32D platform, so that’s the root of the issue rather than anything wrong with your particular setup. The closest reference is the ESP8266 example code. Since both are Arduino-ecosystem boards, that code can be used as a starting point and ported over to the ESP32D.
Okay, that makes sense. Where exactly is that ESP8266 example, and do you have any pointers on what needs to change for the ESP32D?
You can find it in the ArduCAM mini repo under the ESP8266 examples folder:
The idea is to treat that ESP8266 example as your porting reference and adapt it to the ESP32D platform. So to summarize: ArduCAM doesn’t provide ready-made code for the ESP32D, but the ESP8266 example should give you the camera init flow to work from.
