No IMX519_stereo driver for Synchronized Quad Camera Kit IMX519
My goal is to use Synchronized Quad Camera Kit IMX519 on NVIDIA Jetson Xavier NX.
The problem is there is no IMX519_stereo driver. There is only IMX477_stereo. The UC-512 board’s LED is red.
What I’ve did:
  1. do ls /dev/video0 before installing IMX477_stereo, there is no video0 file.
  2. Install IMX477_stereo and reboot. When I tried to use gst-launch-1.0, it throws error.
The error:
[email protected]:~$ ls /dev/video0
/dev/video0
[email protected]:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=1280,height=720,framerate=60/1" ! nvvidconv ! nvoverlaysink
New clock: GstSystemClock
GST_ARGUS: 4056 x 3040 FR = 10,000000 fps Duration = 100000000 ; Analog Gain range min 1,000000, max 22,250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 2028 x 1520 FR = 40,000000 fps Duration = 25000000 ; Analog Gain range min 1,000000, max 22,250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 2028 x 1080 FR = 50,000000 fps Duration = 20000000 ; Analog Gain range min 1,000000, max 22,250000; Exposure Range min 13000, max 683709000;
ARGUS_ERROR: Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute: 895 Frame Rate specified is greater than supported
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 4056 H = 3040
   seconds to Run    = 0
   Frame Rate = 10,000000
ARGUS_ERROR: Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute: 1131 InvalidState.
GST_ARGUS: Cleaning up
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:
streaming stopped, reason error (-5)
Execution ended after 0:00:01.006186682
Setting pipeline to READY ...
(Argus) Error FileOperationFailed: Failed socket read: Connection reset by peer (in src/rpc/socket/common/SocketUtils.cpp, function readSocket(), line 79)
(Argus) Error FileOperationFailed: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error FileOperationFailed: Receive worker failure, notifying 2 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 2 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error FileOperationFailed: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error FileOperationFailed: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error FileOperationFailed:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Caught SIGSEGV
#0  0x0000007f882f0310 in __GI___pthread_timedjoin_ex (threadid=547398607344, thread_return=0x0, abstime=0x0, block=<optimized out>)
#1  0x0000007f883abab8 in  () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2  0x0000007f87b92000 in  ()
Spinning.  Please run 'gdb gst-launch-1.0 9588' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
^C
2nd attempt
[email protected]: ~$ sudo reboot now
   Camera index = 0
   Camera mode  = 0
   seconds to Run    = 0
nvbuf_utils: Can not get HW buffer from FD... Exiting...
CONSUMER: ERROR OCCURRED
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Argus Error Status
Execution ended after 0:00:00.368785945
Setting pipeline to NULL ...
Freeing pipeline ...
/dev/video0
[email protected]:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=2028,height=1080,framerate=30/1" ! nvvidconv ! nvoverlaysink
   Camera index = 0
   Camera mode  = 2
   Output Stream W = 2028 H = 1080
   seconds to Run    = 0
   Frame Rate = 50,000000
Argus Error Status
Execution ended after 0:00:02.181435653
[email protected]:~$ v4l2-ctl --list-ext-formats
bash: v4l2-ctl: command not found
The store:
16MP IMX519 Autofocus Synchronized Quad-Camera Kit for Raspberry Pi, Nvidia Jetson Nano/Xavier NX - Arducam
The quick start guide:
Quick start - Arducam Wiki
@kidfrom
Multi-cam imx519 and mono-cam use the same driver.
Sorry, our docs are missing this part, I’ve asked someone to update it.
./install_full.sh -m imx519
