Hi everyone, hoping someone can help me out. I picked up the 64MP Autofocus Quad-Camera Kit and I can’t get libcamera to see any of the cameras on my Pi.
My setup:
Raspberry Pi 4B, 8GB
64-bit Raspberry Pi OS, latest, fresh install from today
4x Arducam cameras with the 4x-in / 1x-out Camera Array HAT
When I run:
I just get:
No cameras available!
I get the exact same result whether I connect a single camera directly to the Pi, or if I attach the HAT and plug the camera into that. I went through the manual at https://www.arducam.com/downloads/arducam_64mp_pi_camera_manual.pdf and followed the build-and-install instructions starting around page 4, but still nothing.
One thing that’s confusing me — the box the cameras came in says “Only for Camera Array HAT”. What does that mean exactly? Does it matter for what I’m doing? This is getting pretty frustrating, so any pointers would be great.
Sorry you’re hitting this — let’s work through it. First, that “Only for Camera Array HAT” label on the box is just describing how those specific camera modules are intended to be used (they’re built for the array HAT setup). It’s not an error or a warning about your Pi, so don’t worry about that part.
To help narrow this down, can you tell me a few things:
Which Raspberry Pi OS image exactly — full desktop or lite? (You already said 64-bit, thanks.)
When you connect a camera directly to the Pi (no HAT in between), are you using the ribbon cable from the kit, and is it fully seated in the CAM/DISP port with the contacts facing the right direction?
Did you reboot the Pi after running the build-and-install steps in the manual?
Can you paste the exact output of the libcamera-still --list-cameras command, just so I can see the wording verbatim?
The fact that it fails both with the direct connection and through the HAT is actually useful, so let’s start there.
It’s the full desktop image, 64-bit, fresh install from today.
Output is literally just: No cameras available!
Yes, using the ribbon cables that came with the kit. I reseated them a couple of times and the contacts are toward the board.
Yes, I rebooted several times after the build-and-install steps.
I also tried with a single camera plugged straight into the Pi and got the same “No cameras available!” message. Same thing with the HAT attached and the camera connected through it. If it helps, I followed the PDF pages 4+ closely for the build-and-install part, so I don’t think I skipped a step, but I could be wrong.
OK, that’s helpful — the detection failure is happening in both configurations, so we can stop swapping cables for now and get some actual diagnostic output.
Please run these two things and send me the results:
Package versions:
dpkg -l | grep libcamera
A full camera bug report:
camera-bug-report -t 5 -o bug.txt -c “libcamera-still -t 1000 -o test.jpg”
That second command will create a file called bug.txt on your Pi. Please attach that file here so I can go through it.
The dpkg output tells me exactly which libcamera and libcamera-apps versions you have installed, and the bug.txt captures the low-level state (kernel messages, config, sensor detection, etc.). Together those should tell us why libcamera is reporting no cameras — and whether the failure looks the same in the direct connection vs. through the HAT.
Thanks, that’s exactly what I was after. Now can you attach the bug.txt file that the camera-bug-report command created? That’s the piece I still need.
Also, while you’re grabbing it, two quick questions that will help me read it:
Did you change anything in config.txt during the install (any dtoverlay lines added)?
When you connected the camera directly to the Pi, was it the same ribbon cable and the same CAM port you used with the HAT in the middle?
That’ll help me line up what’s in the log with how you have it wired.
Here’s the bug report file I got from the second command: bug.txt
Let me know what you can see in it.
On your other questions: I didn’t touch config.txt myself during the install, and yes, when I connected the camera directly I used the same ribbon cable and the same CAM port as when the HAT is in the middle.
libcamera-apps and libcamera-dev are both 0.0.7 arm64
The “No cameras available!” failure reproduces both with a camera connected directly to the Pi and with the Camera Array HAT in the middle, using the same cable and CAM port
config.txt wasn’t modified by hand during the install
The “Only for Camera Array HAT” label is just describing the intended use of those modules, not a fault
We haven’t pinned down the root cause yet — that’s what the bug.txt is for. I’m going to go through it now to check whether the sensor is showing up at the driver level, whether the overlay/config is loading, and what dmesg has to say. Until that’s clear I can’t point at a specific fix, so I don’t want to guess and send you in circles.
Once I’ve read through the log I’ll follow up here with what I find and the next step. If anything else comes up in the meantime, just post it in this thread.
