B0250 -
- Jetson nano B01
- NVIDIA Jetson nano Developer Kit - Jetpack 4.6 [L4T 32.6.1]
SENSOR_ID=0
FRAMERATE=30
gst-launch-1.0 nvarguscamerasrc sensor-id=$SENSOR_ID ! “video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1” ! nvvidconv ! nvoverlaysink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:725 No cameras available
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.004294877
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Quick-Start-Guide
cd ~
chmod +x install_full.sh
./install_full.sh -m imx477
Error when launching the camera after installing the driver. It says there is no camera available to run. Try changing the sensor ID, the FPS, and the executable code, and the result is the same. -
[ 1.335931] imx477 7-001a: tegracam sensor driver:imx477_v2.0.6
[ 1.636289] imx477 7-001a: imx477_board_setup: error during i2c read probe (-121)
[ 1.643873] imx477 7-001a: board setup failed
[ 1.648346] imx477: probe of 7-001a failed with error -121
[ 1.648699] imx477 8-001a: tegracam sensor driver:imx477_v2.0.6
[ 1.949032] imx477 8-001a: imx477_board_setup: error during i2c read probe (-121)
[ 1.956656] imx477 8-001a: board setup failed
[ 1.961120] imx477: probe of 8-001a failed with error -121 -
- change the camera connector; I had one more camera kit, so I tried changing the connector that plugs into the camera port on the Jetsonano.
GitHub - RidgeRun/NVIDIA-Jetson-IMX477-RPIV3: NVIDIA Jetson IMX477 HQ RPI V3 camera driver
I rebuilt the camera kernel according to the manual, but after rebooting, I got a non-passing error on the NVIDIA screen.
- What help do you need?
I need another workaround that allows me to use the camera.
