No camera found with UC-350 Rev. D on Raspberry Pi 5 using libcamera-hello
Hi all, I’m having trouble with a UC-350 Rev. D camera on a Raspberry Pi 5. Every time I run libcamera-hello I get ‘no camera found’. I’ve tried the same camera on a Raspberry Pi 4 too, and I also tested an official RPI IMX219 v2 as a sanity check — the official camera works fine, so the Pi/libcamera side seems okay. The UC-350 just never gets detected. Any ideas?
Thanks for the info. Let’s gather a bit of diagnostic data. First, could you post photos of the physical connection at both ends — the camera end and the Pi end? I want to check the ribbon orientation and which port it’s plugged into.
While you’re at it, please also generate a bug report so I can see what libcamera sees. Reboot the Pi, then run:
That will write an arducam-bug-report.txt in the current directory. Send that file over (PM is fine) along with the photos.
Here are the photos of the connection at both ends. I’ve also sent over the arducam-bug-report.txt. Let me know if you need anything else.
Thanks, got everything. From the photos the camera looks like it’s on camera port 0 of the Pi 5, so the physical connection isn’t the issue. In the report, libcamera isn’t picking up the IMX219 at all, which points to auto-detection failing on the Pi 5. Let’s switch to a manual device tree overlay.
Run:
sudo nano /boot/firmware/config.txt
Find the line camera_auto_detect=1 and change it to camera_auto_detect=0. Then add this under the [all] section at the bottom:
dtoverlay=imx219
Save, reboot, and try libcamera-hello again.
That worked – simple solution. Thanks a lot for the help!
