Hi there,
I,m having troubles using the autofocus on the 64 mp camera.
durst@pi4:~ $ libcamera-hello
Preview window unavailable
[0:00:29.552565204] [1249] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3896-6019b245
[0:00:29.561626648] [1251] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for 'arducam_64mp'
[0:00:29.561740259] [1251] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
Ioctl read i2c error:: Remote I/O error
[0:00:29.605697982] [1251] WARN RPI raspberrypi.cpp:1280 Mismatch between Unicam and CamHelper for embedded data usage!
[0:00:29.607635500] [1251] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:00:29.607978278] [1251] INFO RPI raspberrypi.cpp:1404 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media1
[0:00:29.609284167] [1249] INFO Camera camera.cpp:1035 configuring streams: (0) 4624x3472-YUV420
[0:00:29.610103222] [1251] INFO RPI raspberrypi.cpp:765 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected unicam format: 4624x3472-pRAA
durst@pi4:~ $ v4l2-ctl -d /dev/v4l-subdev0 --all
User Controls
exposure 0x00980911 (int) : min=9 max=3482 step=1 default=35 value=3482
horizontal_flip 0x00980914 (bool) : default=0 value=0 flags=modify-layout
vertical_flip 0x00980915 (bool) : default=0 value=0 flags=modify-layout
Camera Controls
camera_orientation 0x009a0922 (menu) : min=0 max=2 default=2 value=2 flags=read-only
0: Front
1: Back
2: External
camera_sensor_rotation 0x009a0923 (int) : min=0 max=0 step=1 default=0 value=0 flags=read-only
Image Source Controls
vertical_blanking 0x009e0901 (int) : min=58 max=8385008 step=1 default=58 value=58
horizontal_blanking 0x009e0902 (int) : min=20871 max=20871 step=1 default=20871 value=20871 flags=read-only
analogue_gain 0x009e0903 (int) : min=0 max=1008 step=1 default=0 value=600
red_pixel_value 0x009e0904 (int) : min=0 max=4095 step=1 default=4095 value=4095
green_red_pixel_value 0x009e0905 (int) : min=0 max=4095 step=1 default=4095 value=4095
blue_pixel_value 0x009e0906 (int) : min=0 max=4095 step=1 default=4095 value=4095
green_blue_pixel_value 0x009e0907 (int) : min=0 max=4095 step=1 default=4095 value=4095
Image Processing Controls
pixel_rate 0x009f0902 (int64) : min=900000000 max=900000000 step=1 default=900000000 value=900000000 flags=read-only
test_pattern 0x009f0903 (menu) : min=0 max=4 default=0 value=0
0: Disabled
1: Color Bars
2: Solid Color
3: Grey Color Bars
4: PN9
digital_gain 0x009f0905 (int) : min=256 max=4095 step=1 default=256 value=256
[ 8.033475] arducam_64mp 10-001a: Device found Arducam 64MP.
[ 8.034985] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
Linux pi4 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l GNU/Linux
durst@pi4:~ $ libcamera-hello --autofocus
[0:06:15.163844441] [1267] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3896-6019b245
[0:06:15.167271295] [1269] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for 'arducam_64mp'
[0:06:15.167315536] [1269] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:06:15.182278013] [1269] WARN RPI raspberrypi.cpp:1280 Mismatch between Unicam and CamHelper for embedded data usage!
[0:06:15.183208262] [1269] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:06:15.183366335] [1269] INFO RPI raspberrypi.cpp:1404 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media1
[0:06:15.184014884] [1267] INFO Camera camera.cpp:1035 configuring streams: (0) 4624x3472-YUV420
[0:06:15.184596785] [1269] INFO RPI raspberrypi.cpp:765 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected unicam format: 4624x3472-pRAA
Segmentation fault
Have 2 cameras with 2 cables both not working (clicking on boot). Both worked earlier on arm64 image.
Thx in adv.
LGeorg
