No AF algorithm imx519 raspi zero 2
New Raspberry followed all the instructions on the site and also looked through a few things on here to see how other people fixed it, but nothing seemed to work.
Linux raspberrypi 6.12.34+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.34-1+rpt1~bookworm (2025-06-26) aarch64 GNU/Linux
[0:04:20.434904567] [1903]  INFO RPI vc4.cpp:615 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
[0:04:20.494107597] [1907]  WARN IPARPI ipa_base.cpp:791 Could not set AF_MODE - no AF algorithm
[0:04:20.494834366] [1907]  WARN IPARPI ipa_base.cpp:1249 Could not set AF_SPEED - no focus algorithm
[0:04:20.495239001] [1907]  WARN IPARPI ipa_base.cpp:1231 Could not set AF_RANGE - no focus algorithm
asdf@raspberrypi:~ $ dpkg -l | grep libcamera
ii  libcamera-apps                       1.8.1-1~bookworm                        all          transitional package
ii  libcamera-ipa:arm64                  0.5.1+rpt20250722-1                     arm64        complex camera support library (IPA modules)
ii  libcamera-tools                      0.5.1+rpt20250722-1                     arm64        complex camera support library (tools)
ii  libcamera0.3:arm64                   0.3.2+rpt20241119-1                     arm64        complex camera support library
ii  libcamera0.5:arm64                   0.5.1+rpt20250722-1                     arm64        complex camera support library
ii  libspa-0.2-libcamera:arm64           1.2.7-1~bpo12+1+rpt5                    arm64        libraries for the PipeWire multimedia server - libcamera plugin
ii  pipewire-libcamera                   1.2.7-1~bpo12+1+rpt5                    all          transitional package for libspa-0.2-libcamera
ii  python3-libcamera:arm64              0.5.1+rpt20250722-1                     arm64        complex camera support library (Python bindings)
ii  rpicam-apps                          1.8.1-1~bookworm                        all          Camera based applications for Raspberry Pi using the libcamera framework
ii  rpicam-apps-core                     1.8.1-1~bookworm                        arm64        Camera based applications for Raspberry Pi using the libcamera framework
Hi, and welcome to our community!
I’m sorry to hear you’re running into trouble. It can be frustrating when you’ve followed all the guides and something still isn’t working.
You’ve almost certainly run into a very common software issue. The standard libcamera that comes with a new Raspberry Pi OS doesn’t include the specific autofocus algorithms that our IMX519 camera needs.
The good news is, we have a simple script that installs our customized libcamera version for you. Please run these commands in the terminal:
After the installation is complete, you can run the command below again to double-check if you have installed the specific camera module.
If the libcamera version is correct, you can test the camera with the following command:
rpicam-still -t 0
This should open a live preview from your camera. Let us know if this brings it to life for you.
I already did this and posted my dpkg -l results in my first post, still no AF algo
For some reason, some of you have 3s behind it when mine ends in 2s, though
Following this also doesn’t seem to install dev?
I tried running it all again, but I don’t think there was any change
in other news i put it into a raspeberry pi 5 followed all the steps made sure it was in port zero and activated port zero in config.txt
comes up with everything like yours does but the raspeberry pi cannot find the camera no matter what i do
Could you show me the output of the following command?
cat /boot/firmware/config.txt
sorry, I fixed the raspi 5 one myself but the zero still can’t find auto focus algorithm.
$ cat /boot/firmware/config.txt
# http://rptl.io/configtxt
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
dtoverlay=imx519
Is there anything else you need to diagnose my issue? I have a project I’m trying to finish and this is the only thing preventing me from finishing it.
Did you use the same SD card on your RPI 5 and Pi Zero?
No. I could try to though. Didn’t really think of it.
Alright, I switched it over and removed the point to cm 0 from the pi 5 to the zero 2 w, and it appears to work, does this mean I have a software issue on my other SD card? Guessing the fix is just reflashing the SD and starting from scratch if I want that one to work properly?
