No AF algorithm for imx519 with rpi5
1.Where did you get the camera module(s)?
amazon
2.Model number of the product(s).
Arducam 16MP Autofocus Camera Module for Raspberry Pi with ABS Case, IMX519
3.What hardware/platform were you working on?
Raspberry pi 5
4.Instructions you have followed. (link/manual/etc.)
https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/Quick-Start-Guide/
5.Problems you were having.
Autofocus is not working.
And getting ERROR.
[0:05:57.878126184] [2313] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+245-3c682411-dirty (2024-02-21T01:49:52+00:00)
[0:05:57.887167442] [2316] INFO RPI pisp.cpp:662 libpisp version v1.0.4 6e3a53d137f4 14-02-2024 (14:00:12)
[0:05:57.916082434] [2316] INFO RPI pisp.cpp:1122 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/imx519@1a to CFE device /dev/media1 and ISP device /dev/media0 using PiSP variant BCM2712_C0
Made X/EGL preview window
Mode selection for 2328:1748:12:P
SRGGB10_CSI2P,1280x720/0 - Score: 5319.24
SRGGB10_CSI2P,1920x1080/0 - Score: 3319.24
SRGGB10_CSI2P,2328x1748/0 - Score: 1000
SRGGB10_CSI2P,3840x2160/0 - Score: 1648.24
SRGGB10_CSI2P,4656x3496/0 - Score: 2019
Stream configuration adjusted
[0:05:58.272403294] [2313] INFO Camera camera.cpp:1183 configuring streams: (0) 2328x1748-YUV420 (1) 2328x1748-RGGB16_PISP_COMP1
[0:05:58.272513403] [2316] INFO RPI pisp.cpp:1406 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected CFE format: 2328x1748-PC1R
[0:05:58.284969619] [2322] WARN IPARPI ipa_base.cpp:737 Could not set AF_MODE - no AF algorithm
[0:05:58.285226930] [2322] WARN IPARPI ipa_base.cpp:1119 Could not set AF_SPEED - no focus algorithm
[0:05:58.285301726] [2322] WARN IPARPI ipa_base.cpp:1101 Could not set AF_RANGE - no focus algorithm
Mode selection for 4656:3496:12:P
SRGGB10_CSI2P,1280x720/0 - Score: 13471.2
SRGGB10_CSI2P,1920x1080/0 - Score: 11471.2
SRGGB10_CSI2P,2328x1748/0 - Score: 9152
SRGGB10_CSI2P,3840x2160/0 - Score: 5471.24
SRGGB10_CSI2P,4656x3496/0 - Score: 1000
[0:06:03.479328065] [2313] INFO Camera camera.cpp:1183 configuring streams: (0) 4656x3496-YUV420 (1) 4656x3496-RGGB16_PISP_COMP1
[0:06:03.486448346] [2316] INFO RPI pisp.cpp:1406 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/imx519@1a - Selected sensor format: 4656x3496-SRGGB10_1X10 - Selected CFE format: 4656x3496-PC1R
[0:06:03.492620010] [2349] WARN IPARPI ipa_base.cpp:737 Could not set AF_MODE - no AF algorithm
[0:06:03.492685880] [2349] WARN IPARPI ipa_base.cpp:1119 Could not set AF_SPEED - no focus algorithm
[0:06:03.492722231] [2349] WARN IPARPI ipa_base.cpp:1101 Could not set AF_RANGE - no focus algorithm
Still capture image received
7.Troubleshooting attempts you’ve made.
The information for: sudo dpkg -l | grep libcamera:
ii libcamera-apps 1.4.3-1 all transitional package
ii libcamera-dev:arm64 0.2.0+rpt20240218-1 arm64 complex camera support library (development files)
ii libcamera-ipa:arm64 0.2.0+rpt20240218-1 arm64 complex camera support library (IPA modules)
ii libcamera-tools 0.2.0+rpt20240215-1 arm64 complex camera support library (tools)
ii libcamera0.1:arm64 0.1.0+rpt20231206-1 arm64 complex camera support library
ii libcamera0.2:arm64 0.2.0+rpt20240218-1 arm64 complex camera support library
ii pipewire-libcamera:arm64 0.3.65-3+rpt5+deb12u1 arm64 PipeWire libcamera plugin
ii python3-libcamera:arm64 0.2.0+rpt20240215-1 arm64 complex camera support library (Python bindings)
and the information for: cat /usr/share/libcamera/ipa/raspberrypi/imx519.json:
cat: /usr/share/libcamera/ipa/raspberrypi/imx519.json: No such file or directory
  1. What help do you need?
    I need to fix this error about the af algoritm to get the autofocus and start using the camera
cat /usr/share/libcamera/ipa/rpi/pisp
    "version": 2.0,
    "target": "pisp",
    "algorithms": [
            "rpi.black_level":
                "black_level": 4096
            "rpi.dpc": { }
            "rpi.lux":
                "reference_shutter_speed": 13841,
                "reference_gain": 2.0,
                "reference_aperture": 1.0,
                "reference_lux": 900,
                "reference_Y": 12064
            "rpi.noise":
                "reference_constant": 0,
                "reference_slope": 2.776
            "rpi.geq":
                "offset": 189,
                "slope": 0.01495
            "rpi.denoise":
                "normal":
                    "sdn":
                        "deviation": 1.6,
                        "strength": 0.5,
                        "deviation2": 3.2,
                        "deviation_no_tdn": 3.2,
                        "strength_no_tdn": 0.75
                    "cdn":
                        "deviation": 200,
                        "strength": 0.3
                    "tdn":
                        "deviation": 0.8,
                        "threshold": 0.05
                "hdr":
                    "sdn":
                        "deviation": 1.6,
                        "strength": 0.5,
                        "deviation2": 3.2,
                    "cdn":
                        "deviation": 200,
                        "strength": 0.3
                    "tdn":
                        "deviation": 1.3,
                        "threshold": 0.1
                "night":
                    "sdn":
                        "deviation": 1.6,
                        "strength": 0.5,
                        "deviation2": 3.2,
                    "cdn":
                        "deviation": 200,
                        "strength": 0.3
                    "tdn":
                        "deviation": 1.3,
                        "threshold": 0.1
            "rpi.awb":
                "priors": [
                        "lux": 0,
                        "prior":
                            2000, 1.0,
                            3000, 0.0,
                            13000, 0.0
                        "lux": 800,
                        "prior":
                            2000, 0.0,
                            6000, 2.0,
                            13000, 2.0
                        "lux": 1500,
                        "prior":
                            2000, 0.0,
                            4000, 1.0,
                            6000, 6.0,
                            6500, 7.0,
                            7000, 1.0,
                            13000, 1.0
                "modes":
                    "auto":
                        "lo": 2500,
                        "hi": 7900
                    "incandescent":
                        "lo": 2500,
                        "hi": 3000
                    "tungsten":
                        "lo": 3000,
                        "hi": 3500
                    "fluorescent":
                        "lo": 4000,
                        "hi": 4700
                    "indoor":
                        "lo": 3000,
                        "hi": 5000
                    "daylight":
                        "lo": 5500,
                        "hi": 6500
                    "cloudy":
                        "lo": 7000,
                        "hi": 8000
                "bayes": 1,
                "ct_curve":
                    2890.0, 0.7328, 0.3734,
                    3550.0, 0.6228, 0.4763,
                    4500.0, 0.5208, 0.5825,
                    5700.0, 0.4467, 0.6671,
                    7900.0, 0.3858, 0.7411
                "sensitivity_r": 1.0,
                "sensitivity_b": 1.0,
                "transverse_pos": 0.02027,
                "transverse_neg": 0.01935
            "rpi.agc":
                "metering_modes":
                    "centre-weighted":
                        "weights":
                            0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0,
                            0, 1, 1, 1, 1, 1, 2, 2, 2, 1, 1, 1, 1, 1, 0,
                            1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 1, 1, 1, 1,
                            1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 1, 1,
                            1, 1, 2, 2, 2, 2, 3, 3, 3, 2, 2, 2, 2, 1, 1,
                            1, 1, 2, 2, 2, 3, 3, 3, 3, 3, 2, 2, 2, 1, 1,
                            1, 1, 2, 2, 3, 3, 3, 4, 3, 3, 3, 2, 2, 1, 1,
                            1, 1, 2, 2, 3, 3, 4, 4, 4, 3, 3, 2, 2, 1, 1,
                    "spot":
                        "weights":
                            0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
                            0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0,
                            0, 0, 0, 0, 0, 0, 1, 2, 1, 0, 0, 0, 0, 0, 0,
                            0, 0, 0, 0, 0, 1, 2, 3, 2, 1, 0, 0, 0, 0, 0,
                    "matrix":
                        "weights":
                            1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
                "exposure_modes":
                    "normal":
                        "shutter": [ 100, 10000, 30000, 60000, 120000 ],
                        "gain": [ 1.0, 2.0, 4.0, 6.0, 8.0 ]
                    "short":
                        "shutter": [ 100, 5000, 10000, 20000, 120000 ],
                    "long":
                        "shutter": [ 1000, 30000, 60000, 90000, 120000 ],
                        "gain": [ 1.0, 2.0, 4.0, 6.0, 12.0 ]
                "constraint_modes":
                    "normal": [
                            "bound": "LOWER",
                            "q_lo": 0.98,
                            "q_hi": 1.0,
                            "y_target":
                                0, 0.5,
                                1000, 0.5
                    "highlight": [
                            "bound": "LOWER",
                            "q_lo": 0.98,
                            "q_hi": 1.0,
                            "y_target":
                                0, 0.5,
                                1000, 0.5
                            "bound": "UPPER",
                            "q_lo": 0.98,
                            "q_hi": 1.0,
                            "y_target":
                                0, 0.8,
                                1000, 0.8
                "y_target":
                    0, 0.16,
                    1000, 0.165,
                    10000, 0.17
            "rpi.alsc":
                "omega": 1.3,
                "n_iter": 100,
                "luminance_strength": 0.5,
                "calibrations_Cr": [
                        "ct": 3000,
                        "table":
                            1.527, 1.524, 1.521, 1.515, 1.509, 1.502, 1.494, 1.486, 1.478, 1.469, 1.458, 1.451, 1.445, 1.442, 1.441, 1.441, 1.441, 1.441, 1.441, 1.442, 1.446, 1.451, 1.46, 1.469, 1.477, 1.484, 1.489, 1.495, 1.499, 1.503, 1.504, 1.504,
                            1.526, 1.522, 1.518, 1.512, 1.505, 1.497, 1.489, 1.481, 1.473, 1.462, 1.451, 1.443, 1.436, 1.432, 1.431, 1.43, 1.43, 1.43, 1.431, 1.434, 1.438, 1.444, 1.454, 1.463, 1.471, 1.479, 1.485, 1.491, 1.496, 1.5, 1.502, 1.504,
                            1.526, 1.521, 1.516, 1.508, 1.501, 1.492, 1.483, 1.475, 1.467, 1.456, 1.444, 1.435, 1.428, 1.423, 1.42, 1.418, 1.418, 1.419, 1.422, 1.425, 1.431, 1.438, 1.447, 1.457, 1.466, 1.474, 1.482, 1.488, 1.493, 1.498, 1.5, 1.503,
                            1.524, 1.519, 1.513, 1.505, 1.496, 1.487, 1.478, 1.469, 1.461, 1.45, 1.437, 1.427, 1.419, 1.413, 1.409, 1.407, 1.407, 1.408, 1.412, 1.417, 1.423, 1.431, 1.441, 1.45, 1.46, 1.469, 1.477, 1.485, 1.49, 1.495, 1.499, 1.502,
                            1.522, 1.516, 1.51, 1.502, 1.493, 1.483, 1.472, 1.462, 1.452, 1.441, 1.429, 1.419, 1.409, 1.402, 1.397, 1.395, 1.395, 1.397, 1.401, 1.406, 1.414, 1.422, 1.433, 1.443, 1.453, 1.462, 1.471, 1.48, 1.486, 1.492, 1.496, 1.5,
                            1.519, 1.513, 1.508, 1.499, 1.489, 1.478, 1.467, 1.455, 1.443, 1.432, 1.421, 1.41, 1.399, 1.391, 1.386, 1.383, 1.383, 1.386, 1.39, 1.396, 1.405, 1.414, 1.425, 1.436, 1.446, 1.456, 1.466, 1.475, 1.483, 1.49, 1.493, 1.497,
                            1.516, 1.511, 1.505, 1.495, 1.485, 1.473, 1.461, 1.448, 1.435, 1.423, 1.412, 1.401, 1.389, 1.381, 1.375, 1.372, 1.372, 1.374, 1.379, 1.386, 1.396, 1.406, 1.418, 1.429, 1.439, 1.449, 1.46, 1.47, 1.479, 1.487, 1.491, 1.494,
                            1.515, 1.508, 1.502, 1.491, 1.48, 1.467, 1.454, 1.441, 1.427, 1.415, 1.404, 1.392, 1.38, 1.371, 1.364, 1.361, 1.361, 1.363, 1.369, 1.377, 1.388, 1.398, 1.409, 1.42, 1.431, 1.443, 1.454, 1.465, 1.475, 1.484, 1.488, 1.492,
                            1.513, 1.505, 1.498, 1.487, 1.475, 1.461, 1.448, 1.434, 1.419, 1.407, 1.396, 1.383, 1.37, 1.361, 1.353, 1.349, 1.349, 1.352, 1.359, 1.367, 1.379, 1.391, 1.401, 1.412, 1.424, 1.436, 1.448, 1.46, 1.471, 1.481, 1.485, 1.49,
                            1.511, 1.503, 1.495, 1.483, 1.47, 1.456, 1.442, 1.427, 1.412, 1.399, 1.387, 1.375, 1.362, 1.352, 1.344, 1.34, 1.34, 1.343, 1.35, 1.36, 1.371, 1.383, 1.393, 1.405, 1.418, 1.431, 1.443, 1.455, 1.467, 1.478, 1.483, 1.488,
                            1.51, 1.501, 1.492, 1.479, 1.466, 1.451, 1.436, 1.421, 1.406, 1.392, 1.378, 1.366, 1.355, 1.346, 1.336, 1.332, 1.332, 1.335, 1.344, 1.353, 1.363, 1.374, 1.385, 1.398, 1.412, 1.425, 1.439, 1.452, 1.463, 1.475, 1.481, 1.486,
                            1.508, 1.499, 1.489, 1.475, 1.461, 1.446, 1.43, 1.414, 1.399, 1.384, 1.369, 1.358, 1.348, 1.339, 1.329, 1.324, 1.323, 1.328, 1.338, 1.347, 1.355, 1.365, 1.378, 1.391, 1.406, 1.42, 1.434, 1.448, 1.46, 1.472, 1.478, 1.484,
                            1.508, 1.497, 1.487, 1.473, 1.459, 1.443, 1.426, 1.41, 1.394, 1.379, 1.363, 1.351, 1.342, 1.333, 1.325, 1.321, 1.32, 1.324, 1.332, 1.34, 1.349, 1.359, 1.372, 1.386, 1.401, 1.416, 1.43, 1.445, 1.457, 1.47, 1.477, 1.484,
                            1.507, 1.496, 1.485, 1.471, 1.457, 1.441, 1.424, 1.407, 1.391, 1.375, 1.359, 1.346, 1.335, 1.327, 1.322, 1.319, 1.319, 1.321, 1.326, 1.333, 1.343, 1.354, 1.368, 1.382, 1.397, 1.412, 1.427, 1.442, 1.455, 1.468, 1.476, 1.483,
                            1.507, 1.495, 1.483, 1.469, 1.455, 1.439, 1.422, 1.404, 1.387, 1.371, 1.355, 1.341, 1.328, 1.321, 1.319, 1.318, 1.318, 1.319, 1.321, 1.326, 1.338, 1.35, 1.363, 1.378, 1.393, 1.408, 1.424, 1.439, 1.453, 1.466, 1.474, 1.483,
                            1.507, 1.495, 1.483, 1.469, 1.455, 1.438, 1.421, 1.404, 1.387, 1.37, 1.354, 1.34, 1.327, 1.32, 1.318, 1.316, 1.316, 1.317, 1.32, 1.326, 1.337, 1.35, 1.363, 1.377, 1.393, 1.408, 1.424, 1.439, 1.452, 1.466, 1.474, 1.483,
                            1.507, 1.495, 1.483, 1.469, 1.455, 1.438, 1.421, 1.404, 1.387, 1.37, 1.354, 1.34, 1.327, 1.32, 1.316, 1.315, 1.315, 1.316, 1.319, 1.326, 1.337, 1.35, 1.363, 1.377, 1.393, 1.408, 1.424, 1.439, 1.452, 1.466, 1.474, 1.483,
                            1.507, 1.495, 1.483, 1.469, 1.455, 1.438, 1.422, 1.404, 1.387, 1.37, 1.355, 1.341, 1.328, 1.32, 1.315, 1.313, 1.313, 1.315, 1.319, 1.326, 1.338, 1.35, 1.363, 1.377, 1.393, 1.408, 1.424, 1.439, 1.452, 1.466, 1.474, 1.483,
                            1.507, 1.495, 1.484, 1.47, 1.456, 1.439, 1.423, 1.406, 1.389, 1.372, 1.357, 1.343, 1.331, 1.323, 1.318, 1.316, 1.316, 1.318, 1.323, 1.33, 1.34, 1.352, 1.366, 1.38, 1.395, 1.41, 1.425, 1.44, 1.453, 1.466, 1.475, 1.483,
                            1.507, 1.496, 1.485, 1.471, 1.456, 1.44, 1.424, 1.407, 1.39, 1.374, 1.359, 1.346, 1.335, 1.326, 1.32, 1.318, 1.319, 1.321, 1.327, 1.334, 1.343, 1.354, 1.368, 1.383, 1.398, 1.412, 1.427, 1.442, 1.455, 1.467, 1.475, 1.483,
                            1.507, 1.497, 1.486, 1.472, 1.458, 1.442, 1.426, 1.41, 1.393, 1.377, 1.362, 1.35, 1.339, 1.331, 1.324, 1.321, 1.322, 1.325, 1.331, 1.338, 1.347, 1.357, 1.372, 1.386, 1.4, 1.415, 1.429, 1.443, 1.456, 1.468, 1.475, 1.483,
                            1.507, 1.497, 1.487, 1.474, 1.46, 1.445, 1.43, 1.414, 1.398, 1.382, 1.368, 1.356, 1.347, 1.338, 1.329, 1.326, 1.326, 1.33, 1.337, 1.345, 1.353, 1.364, 1.377, 1.39, 1.405, 1.419, 1.432, 1.446, 1.458, 1.469, 1.476, 1.483,
                            1.508, 1.498, 1.489, 1.476, 1.463, 1.448, 1.433, 1.418, 1.402, 1.388, 1.373, 1.363, 1.354, 1.345, 1.335, 1.33, 1.331, 1.334, 1.343, 1.351, 1.36, 1.37, 1.382, 1.394, 1.409, 1.422, 1.435, 1.448, 1.46, 1.471, 1.477, 1.484,
                            1.508, 1.499, 1.49, 1.478, 1.466, 1.452, 1.437, 1.422, 1.407, 1.394, 1.381, 1.37, 1.361, 1.352, 1.342, 1.338, 1.338, 1.341, 1.349, 1.358, 1.367, 1.377, 1.388, 1.4, 1.413, 1.427, 1.439, 1.451, 1.462, 1.472, 1.478, 1.484,
                            1.51, 1.501, 1.492, 1.481, 1.469, 1.455, 1.441, 1.427, 1.413, 1.4, 1.389, 1.378, 1.368, 1.359, 1.351, 1.347, 1.347, 1.35, 1.357, 1.364, 1.375, 1.385, 1.395, 1.406, 1.419, 1.432, 1.443, 1.455, 1.465, 1.474, 1.48, 1.486,
                            1.511, 1.502, 1.494, 1.483, 1.472, 1.459, 1.445, 1.431, 1.418, 1.407, 1.398, 1.387, 1.375, 1.366, 1.36, 1.357, 1.357, 1.359, 1.364, 1.371, 1.382, 1.393, 1.402, 1.412, 1.424, 1.436, 1.447, 1.458, 1.467, 1.477, 1.482, 1.487,
                            1.511, 1.503, 1.495, 1.485, 1.475, 1.462, 1.449, 1.436, 1.424, 1.414, 1.405, 1.394, 1.383, 1.375, 1.37, 1.368, 1.368, 1.369, 1.373, 1.38, 1.39, 1.4, 1.409, 1.418, 1.43, 1.441, 1.451, 1.461, 1.469, 1.478, 1.482, 1.487,
                            1.511, 1.503, 1.496, 1.486, 1.477, 1.465, 1.453, 1.442, 1.431, 1.421, 1.412, 1.402, 1.392, 1.385, 1.381, 1.378, 1.378, 1.38, 1.383, 1.389, 1.398, 1.406, 1.415, 1.424, 1.436, 1.446, 1.455, 1.464, 1.471, 1.478, 1.483, 1.487,
                            1.511, 1.504, 1.496, 1.488, 1.479, 1.468, 1.457, 1.447, 1.437, 1.428, 1.418, 1.409, 1.401, 1.395, 1.391, 1.389, 1.389, 1.39, 1.393, 1.398, 1.405, 1.413, 1.421, 1.431, 1.441, 1.452, 1.459, 1.466, 1.473, 1.479, 1.483, 1.487,
                            1.511, 1.504, 1.496, 1.488, 1.479, 1.469, 1.459, 1.45, 1.442, 1.433, 1.424, 1.416, 1.408, 1.403, 1.4, 1.399, 1.399, 1.4, 1.402, 1.406, 1.412, 1.419, 1.427, 1.436, 1.446, 1.455, 1.462, 1.468, 1.474, 1.48, 1.484, 1.487,
                            1.511, 1.503, 1.496, 1.488, 1.479, 1.47, 1.461, 1.453, 1.446, 1.438, 1.429, 1.422, 1.415, 1.411, 1.41, 1.409, 1.409, 1.41, 1.411, 1.413, 1.419, 1.425, 1.433, 1.441, 1.45, 1.457, 1.464, 1.47, 1.476, 1.481, 1.484, 1.487,
                            1.511, 1.503, 1.496, 1.487, 1.479, 1.471, 1.464, 1.457, 1.45, 1.442, 1.435, 1.428, 1.422, 1.419, 1.419, 1.419, 1.419, 1.419, 1.419, 1.421, 1.426, 1.432, 1.439, 1.447, 1.454, 1.46, 1.466, 1.472, 1.477, 1.482, 1.485, 1.487
                        "ct": 6000,
                        "table":
                "sigma": 0.00372,
                "sigma_Cb": 0.00244
            "rpi.contrast":
                "ce_enable": 1,
                "gamma_curve":
                    0, 0,
                    1024, 5040,
                    2048, 9338,
                    3072, 12356,
                    4096, 15312,
                    5120, 18051,
                    6144, 20790,
                    7168, 23193,
                    8192, 25744,
                    9216, 27942,
                    10240, 30035,
                    11264, 32005,
                    12288, 33975,
                    13312, 35815,
                    14336, 37600,
                    15360, 39168,
                    16384, 40642,
                    18432, 43379,
                    20480, 45749,
                    22528, 47753,
                    24576, 49621,
                    26624, 51253,
                    28672, 52698,
                    30720, 53796,
                    32768, 54876,
                    36864, 57012,
                    40960, 58656,
                    45056, 59954,
                    49152, 61183,
                    53248, 62355,
                    57344, 63419,
                    61440, 64476,
                    65535, 65535
            "rpi.ccm":
                "ccms": [
                        "ct": 2890,
                        "ccm":
                            1.36754, -0.18448, -0.18306,
                            -0.32356, 1.44826, -0.12471,
                            -0.00412, -0.69936, 1.70348
                        "ct": 2920,
                        "ccm":
                            1.26704, 0.01624, -0.28328,
                            -0.28516, 1.38934, -0.10419,
                            -0.04854, -0.82211, 1.87066
                        "ct": 3550,
                        "ccm":
                            1.42836, -0.27235, -0.15601,
                            -0.28751, 1.41075, -0.12325,
                            -0.01812, -0.54849, 1.56661
                        "ct": 4500,
                        "ccm":
                            1.36328, -0.19569, -0.16759,
                            -0.25254, 1.52248, -0.26994,
                            -0.01575, -0.53155, 1.54729
                        "ct": 5700,
                        "ccm":
                            1.49207, -0.37245, -0.11963,
                            -0.21493, 1.40005, -0.18512,
                            -0.03781, -0.38779, 1.42561
                        "ct": 7900,
                        "ccm":
                            1.34849, -0.05425, -0.29424,
                            -0.22182, 1.77684, -0.55502,
                            -0.07403, -0.55336, 1.62739
            "rpi.sharpen": { }
I tried but still not working
libcamera-still -t 0 --tuning-file /usr/share/libcamera/ipa/rpi/pisp/imx519.json
[0:13:37.393911008] [2243]  INFO Camera camera_manager.cpp:284 libcamera v0.1.0+245-3c682411-dirty (2024-02-21T01:49:52+00:00)
[0:13:37.403168697] [2246]  INFO RPI pisp.cpp:662 libpisp version v1.0.4 6e3a53d137f4 14-02-2024 (14:00:12)
[0:13:37.419526834] [2246]  INFO RPI pisp.cpp:1122 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/imx519@1a to CFE device /dev/media0 and ISP device /dev/media1 using PiSP variant BCM2712_C0
[0:13:37.815205372] [2243]  INFO Camera camera.cpp:1183 configuring streams: (0) 2328x1748-YUV420 (1) 2328x1748-RGGB16_PISP_COMP1
[0:13:37.815354815] [2246]  INFO RPI pisp.cpp:1406 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected CFE format: 2328x1748-PC1R
[0:13:37.826681835] [2258]  WARN IPARPI ipa_base.cpp:737 Could not set AF_MODE - no AF algorithm
[0:13:37.826764316] [2258]  WARN IPARPI ipa_base.cpp:1119 Could not set AF_SPEED - no focus algorithm
[0:13:37.826806112] [2258]  WARN IPARPI ipa_base.cpp:1101 Could not set AF_RANGE - no focus algorithm
@Edward can you kindly please fix my issue of camera imx519 not detecting AF algorithms, many thanks in advance
Hi @qas
Can you send us pictures of the FFC you are using?
here it is
this error I get when use the AF cmd
We updated the software just now. Please follow the steps below to install the libcamera and run the preview window:
# Install the libcamera
#Run the command below to see if autofocus is working or not
Looking forward to your feedback.
Dion
it has detected the ‘AF Algorithm’ but some of it’s modes are not working properly for example:
‘libcamera-still -t -0 --autofocus mode continuous’
‘libcamera-still -t -0 --autofocus mode manual’ (cannot use keyboard stroke ‘a’ and ‘d’ to manually control focus
note: I still haven’t tested the ‘libcamera-vid’ command yet
attached picture is the commands I used, ‘X’ represents not working
I just checked ‘AF continuous’ on Picamera2 lib, its working.
Update:
I just recheck libcamera commands
‘libcamera-still -t 0 --autofocus-mode continuous’ is working fine
but in ‘AF manual mode’ I still cant use Keyboard strokes ‘a’ and ‘d’ or ‘f’ to manually change ‘lens positions’
Hi @qas
Thank you for the update :slight_smile:
Regarding the ‘AF manual mode’, I suggest that you can refer to the picture below to use the keyboard to control the focus motor.
I am now getting this error again.
Fully updated Pi5 with imx519.
Any idea if there is a new software update?
2025 and im getting this error again, running a rpi 5
Could you elaborate on your problem? Any issue log or screenshot is appreciated.
exact same problem as above, Im on a pi 5 and on latest pi os
We pushed the latest libcamera-apps to our GitHub this morning. Could you plz reinstall the libcamera software with the following commands again?
I found the solution,
i had to run
sudo apt install raspberrypi-kernel
and then reinstall everything. works great now
