New arducams UC-788 Rev.B not visible in RPI4 even with -i2cdetect
We have ordered 110 cameras ArduCam B0165, the PCB of the camera has message UC-788 Rev.B. The mipi cable has message Arducam UC-376
Previously we bought a few items from the local shop they worked fine. The new cameras which came to us in this big batch of 110 items are not recongnized by RaspberryPi 4 . We tried re-inserting them or using them with different RPI boards and SOMETIMES (very rarely) they are visible on i2c bus and working. But after reboot the connection to the camera may be lost again and they are not visible on i2c bus.
We have tried to replace camera mipi cable and it does not show any promising results.
Inserting into the same RaspberyPi the old B0165 Arducams that we bought earlier work fine.
This issue is MAJOR for us because we can fail mid-size project devices supply to our customer based on Arducam cameras and that will be disaster. Please, help.
Additional information found.
  1. the dmesg command reveals the difference in the boot log when camera is found and when it is not found:
[ 5.637154] ov9281 10-0060: Detected OV009281 sensor
OR
[ 5.392927] ov9281 10-0060: Unexpected sensor id(689c0400), ret(-5)
  1. We found temporary workaround - if you de-initialise i2c mux and then initialize it, then at certain attempt you can get camera recognized by the system
  2. We have investigated switching sensor on the camera PCB in several combinations
    old PCB - old Sensor = 100% success (camera visible upon boot)
    old PCB - new Sensor = 70% success
    new PCB - old Sensor = 50% success
    new PCB - new Sensor = 20% success
  3. We found that new camera and old camera have some visual difference on the sensor cable
  4. The i2c debugger attached to camera i2c bus reveals some randomness of addresses in the i2c packets shotly after camera startup, which likely is the cause of camera not recognized by the system
Conclusion - we will rise the dispute to return the defective Arducam B0165 cameras. This is very pity that Arducam brand was compromised in our case as we will likely fail our project for our customer because of this bad batch.
Hi there,
It’s a known issue, and we’ve got it sorted out. We replaced the power chip on the camera board, which will increase the time for the power-en, as a result of the detection failure.
Could you please plus , arducam behind dtoverlay=ov9281 in the config.txt file?
Finally, you need to add dtoverlay=ov9281,arducam to the config.txt, and then reboot your Pi to take effect.
Please let me know if that works for you.
No, unfortunately this “,arducam” does not have any effect. Maybe our driver is old? Can you provide link to the latest driver installation for RPI 4 ?
We tested on 2 different combinations of RPI and Arducam. Our trick mentioned above still does the work for both.
Hi @skribtsov
Is it possible to connect to your RPI 4? We wanted to remote into your Pi to debug. If you’re comfortable with it, please install AnyDesk on your Raspberry Pi and DM me the AnyDesk ID.
Dion, thank you ! This is very kind to hear this support from you! I’ll ask some assistance and reply soon.
Update: I have our engineers started working on remote connection… stand by… This may take 30-60 mins I guess.
The problem that we’re using 32 bit OS and AnyDesk exist only for 64 bit OS. We’re considering other methods to make SSH connection for you but I need your e-mail to share some private account data
For sure.
You can contact me at [email protected].
My collegua Konstantin prepared remote access for you a few days ago, did you manage to login and check what’s happening?
For sure. I left a message on his PC.
