Hi everyone, I’m trying to get a Jetvariety driver (.deb) working for an OV2311 (B0221) camera on my Jetson Orin NX with a Seeed A603 carrier board. Here’s my environment:
Kernel: 5.15.148-tegra-36.4.4-20250616085344
Jetson: NVIDIA Jetson Orin NX (leetop 603 Kit)
JetPack: 6.1
L4T: 36.4.4
Camera: OV2311 (B0221)
Carrier: Seeed A603 (third-party)
I can’t seem to find a compatible driver build for this L4T version. Is there one available, or am I missing something? Any pointers would be appreciated.
Looking at your setup, the issue is that L4T 36.4.4 is a very recent release — it just dropped and we haven’t completed adapting and validating the Jetvariety driver for this version yet. That’s why you’re not finding a matching build.
There’s also another thing to keep in mind: the Seeed A603 is a third-party carrier board. Even once we have a driver ready for L4T 36.4.4, compatibility with that particular carrier isn’t guaranteed. The Jetvariety driver is developed and tested against the official NVIDIA Jetson carrier boards, and third-party boards can introduce hardware-level differences that interfere.
I’ve flagged this with the engineering team so they can start working on the L4T 36.4.4 adaptation. I’ll update this thread once there’s progress.
Thanks for the quick response. Just following up — any update on the driver build for L4T 36.4.4? I’m working on a pretty important project that depends on getting this OV2311 camera integrated, so I’m kind of stuck until this is available. Appreciate any news you might have.
Still waiting on the engineering team, I’m afraid. The request is flagged and they’re aware of it, but there’s no stable build available for L4T 36.4.4 just yet. I know that’s not what you want to hear when you’re blocked on a project — I’ll ping them again and let you know the moment something is ready.
That filename tells you what it’s built for: t234-nx (Jetson Orin NX), kernel 5.15.148-tegra-36.4.4, compiled on 2025-07-03. So it should match your kernel version exactly.
I’ve sent you the actual .deb package through private message — check your inbox.
Now, the caveat I mentioned earlier still applies: this was not tested on the Seeed A603 carrier board, and third-party carriers can cause issues ranging from camera detection failures to bus errors. Keep that in mind before you go too far down the troubleshooting rabbit hole.
To install, once you’ve downloaded the file from the private message:
If you hit installation problems or the camera isn’t detected after install, the first thing I’d suggest is trying the same setup on an official NVIDIA Jetson carrier board to rule out the Seeed A603 as the source of the issue. The driver builds are kernel-version-specific, so even small differences in how a third-party board handles the CSI lanes or I2C routing can prevent things from working correctly.
