Need config file for 200MP Arducam Camera (B0527)
    Scorpion Vision
    B0527
    Ubuntu
    Quick Start Guide on Linux - Arducam Wiki
  5. Problems you were having?
    I am trying to access the higher resolutions on this 200MP Arducam camera. On Linux I only have access to 1280x720 via UVC (or 2MP), which is far below 200MP. Reading the specs advertised on the camera’s page:
    Frame Rate (USB 3.0)* YUV: 1280×720@120fps, 1920×1080@60fps, 3840×2160@20fps,
    4080×3072@13fps,8160×6144@3fps
    RAW: 16320×6144@1fps**
    I should see these options, but I only see:
    ❯ v4l2-ctl --device=/dev/video0 --list-formats-ext
    ioctl: VIDIOC_ENUM_FMT
    Type: Video Capture
     [0]: 'YUYV' (YUYV 4:2:2)
                     Interval: Discrete 0.100s (10.000 fps)
I tried to use the driver code at EVK (GitHub - ArduCAM/ArduCam_EVK_Demo) but it cannot seem to find the device, and there exists no config for this Camera. What do you suggest I do?
Looks like it’s detected as a UVC 2.0 device on your Linux OS. Please check the following doc:
https://docs.arducam.com/UVC-Camera/Troubleshooting/#2-camera-detected-as-usb-20-uvc-20-instead-of-usb-30-uvc-30
In the meantime, please note that it doesn’t support the 200MP on Linux OS. You can check here:
https://docs.arducam.com/UVC-Camera/Appilcation-Note/USB3-200MP-Camera/Quick-Start-Guide-on-Linux/#note
Thanks for your response. You are correct, it was being detected as UVC 2.0 instead of UVC3.0, and now i have access to all the resolutions advertised on the product page.
One last question, I would like to ask if it’s possible to capture still images directly from the camera without having to take them from the video stream? Our camera will be moving and we want to reduce the blur in the images we take, which is very high in higher resolutions.
Thanks in advance.
