Need Arducam camera schematics: XVS pin for sync on Jetson Orin NX (B0251, IMX477, IMX519)
Hey everyone, I’m working on an agricultural robotics application and need some help with camera synchronization. I’m looking at three Arducam modules:
  • Arducam MINI High Quality Camera with M12 mount lens (B0251)
  • IMX477 12MP High Quality Camera with motorized focus/autofocus
  • Arducam IMX519 Autofocus Camera Module for Raspberry Pi
I need to sync multiple shutters with a strobing LED bar. The cameras are attached to separate NVIDIA Jetson Orin NX units (MIPI-CSI 2, 4-lane), and they’re not close enough to use FPC/FFC cables between them.
Does anyone know if the XVS (vertical sync) pin is broken out on any of these boards? I’d also like to get schematics and datasheets for these modules if possible — trying to figure out if FSIN, XVS, or any strobe pin is accessible somewhere on the PCBs. Any other methods for camera sync across multiple hosts would also be appreciated.
Thanks for reaching out. Looking at the modules you’ve listed — the IMX477, IMX519, and B0251 — none of these camera modules support hardware synchronization natively in the way you’re describing. Long-distance synchronization across separate hosts is going to be unstable with these particular modules.
We do have some quad-camera synchronization kits that might be worth looking at:
  • B0397 Arducam 12MP×4 477P Quadrascopic Camera Bundle Kit (FFC cable limit: ~50cm)
  • B0388 16MP IMX519 Autofocus Synchronized Quad-Camera Kit
For global shutter cameras with external trigger, there’s also documentation here: External Trigger Mode - Arducam Wiki
What’s your resolution requirement? The global shutter options may be worth considering if 4K isn’t a hard requirement.
Appreciate the response, but those quad-camera kits won’t work for us. We need 4K resolution per camera at 30fps+, and we specifically don’t want multiple cameras multiplexed into a single frame. That defeats the purpose — we need independent 4K streams from each unit.
The FFC cable length limitation is also a dealbreaker. Our cameras are mounted on different parts of the robot, connected to separate Jetson Orin NX modules. They’re physically too far apart for 50cm ribbons.
I spent some time scoping the FSTROBE and XVS lines on the IMX477 module (the motorized focus version from uctronics). Here’s what I observed:
  • FSTROBE stays low the entire time while capturing
  • XVS goes high and stays high for the duration of all buffers — it never toggles
There are several unlabeled vias on the board near these signals. Anyone know if any of those vias are tied to FSIN, XVS, or a strobe output? Schematics would really help here.
Also, the global shutter cameras you linked don’t hit the 4K spec we need, so that’s not an option. Budget is around $200-300/unit, annual volume 30-50 units.
I understand the constraints better now. For the sync question, you might find some useful background in these resources:
These discuss the synchronization architecture on the Raspberry Pi camera stack. That said, I should be upfront — the modules you’ve purchased don’t expose XVS/FSIN in a way that’s usable for external trigger across independent hosts. The sync pins that exist on the IMX477 sensor itself aren’t broken out on these particular camera boards in an accessible way.
Yeah, I’ve gone through those links — they’re all Raspberry Pi specific. The Jetson Orin NX doesn’t have /boot/firmware/config.txt or the same camera stack, so a lot of those software sync methods don’t translate directly.
What I really need is a hardware-level answer: can FSTROBE be enabled on the IMX477 module? Can XVS behavior be customized so it actually toggles per frame rather than staying high? Are any of those unlabeled vias on the board usable?
I’m fine soldering to test points if I know what they are. Has anyone successfully tapped a frame sync signal from any of the B0251, IMX477, or IMX519 Arducam boards? Even a vertical sync pulse per frame would let us drive the LED strobe timing externally.
Separate but related issue — I also have one of the Arducam xISP/Klarity camera modules here, and I tried removing the ISP FPGA board to see if I could get a direct sensor readout at higher speed. Physically disconnected it from the board. Now I’m getting a bunch of I2C read/write errors and no image at all.
Attaching dmesg logs from both configurations (with ISP board and without). Should there be something else routing the signals if the ISP board is removed, or does the sensor simply not work without that FPGA in the path? I was hoping to bypass the ISP to get raw frames out faster.
On the xISP/Klarity module — the camera board cannot operate without the ISP baseboard attached. The FPGA on that baseboard handles signal routing and I2C communication with the sensor. Removing it breaks the entire pipeline, which is exactly what you’re seeing with those I2C errors. There’s no way to get image output without it. You’d need a custom breakout or different hardware altogether to interface with the sensor directly.
Understood on the ISP board being required. So let me ask this differently: with the ISP board still attached, is there any way to disable the ISP processing in software? The pipeline is way too slow — we need much higher frame rates and the ISP seems to be the bottleneck. Is there a register, a driver flag, or some mode that bypasses the ISP and just gives us raw frames?
Unfortunately, the ISP cannot be turned off on the xISP/Klarity hardware. There’s no software switch or driver flag to bypass it. That said, even if bypass were possible, the speed improvement would only be relevant if you’re trying to capture RAW images — and at full resolution you’re still looking at around 8fps maximum on this platform.
What frame rate are you aiming for, and at what resolution? That’ll help narrow down whether this hardware can meet your needs at all.
Target is raw Bayer output at 5120×3840 at 30fps. That’s 20MP — and with the ISP off it should be well within what the MIPI lanes can handle. 8fps with the ISP on is unusable for our application. The sensor itself is capable of much more than 8fps at full res in raw mode. The bottleneck is clearly the ISP FPGA pipeline.
Is there any plan to allow ISP bypass in firmware, or is this a permanent hardware limitation? If the latter, are there any other Arducam modules that can do 4K+ raw Bayer at 30fps without an ISP in the way?
