Hi everyone, I’m running into a really worrying issue with my new Arducam 12MP IMX708 wide angle camera (SKU B0310) on a Raspberry Pi 5 8GB running the latest Bookworm OS.
Every time I connect the camera via the 22-pin ribbon cable and power on the Pi 5, the board immediately shuts down. No boot, no LEDs — just completely dead until I disconnect the camera. I’ve tried multiple times and I’m now worried I might have already damaged something.
I also tried installing the 4-lane IMX708 driver following some guides I found, but the installation kept failing. Not sure if that’s related.
Is the IMX708 even compatible with the Pi 5? Anyone else had this issue?
Stop testing immediately — you’re very likely causing a short circuit, and continuing could permanently damage your Pi 5 or the camera module.
Here’s what’s going on: SKU B0310 actually has two hardware revisions floating around under the same SKU:
Older revision: Uses a high-density 22-pin connector on the board (sometimes people count 21 pins by eye, but it’s 22).
Newer revision: Updated to a standard 15-pin CSI connector, matching standard Raspberry Pi accessories.
The instant shutdown you’re seeing is the Pi 5’s overcurrent/short-circuit protection kicking in. This typically happens when the ribbon cable pin mapping doesn’t match what the board expects — essentially sending voltage where it shouldn’t go.
A lot of this comes down to cable orientation. 22-pin ribbon cables come in two types:
Forward (same-side): The metal contact pads are on the same side at both ends.
Reverse (opposite-side): The metal contact pads are on opposite sides.
Using the wrong type for your specific board revision will short things out.
As for the 4-lane driver issue — the current Raspberry Pi OS Bookworm kernel does not natively support the 4-lane IMX708 configuration, so those installation failures are expected and unrelated to the shutdown problem.
Next step: Can you post clear photos showing both ends of the 22-pin cable you’re using? I need to see whether the contacts are on the same side or opposite sides. And please don’t power it up again until we sort this out.
Thanks for the quick response — glad I asked before trying again.
Here are the photos of my cable. It’s a 22-pin cable (not 21 — I double-checked), and as far as I can tell it’s the “forward” type. The metal pads are on the same side at both ends.
Yeah, that confirms it — that cable is not correct for your camera module. What you’ve got there is a forward-type (same-side contacts) 22-pin cable, and it’s almost certainly the reason your Pi 5 is shorting out on boot.
The camera module should have come with a white 22-to-22 pin cable in the package. That’s the one you need to be using. Can you check the box and see if you have that white cable in there? It should have been included from the factory.
The difference between these cables seems minor, but the pin mapping is completely different — one sends signals to the right places, the other sends power straight into the ground plane. Hence the instant shutdown.
Okay, so I checked the packaging and here’s where it gets a bit confusing.
The camera I originally had here is what I think is the “old” revision — the PCB says UC-A65 Rev. A with the 22-pin connector. But in that box, the only cable included was a brown 15-to-21 pin cable. No white 22-to-22 pin cable at all.
Looking at the product images on your site, it seems like the correct cable for this old revision might actually be a reverse (opposite-side) 22-to-22 pin cable, not forward:
Can you confirm — for the UC-A65 Rev. A board, do I need a reverse-type 22-to-22 pin cable? If so, I’ll just go ahead and buy one and report back once I’ve tested it.
Quick update — I managed to sort this out and wanted to share what I found in case it helps anyone else.
Turns out I had a mix-up with my orders. I actually received the new revision (UC-B47 Rev. A with the 15-pin CSI connector) from a recent order, not the old UC-A65 as I’d assumed. The UC-B47 Rev. A box includes two cables:
A 15-to-22 pin cable
A 22-to-22 pin cable with contacts on opposite sides (reverse type)
So my original problem was 100% user error — I’d grabbed a random forward-type 22-pin cable I had lying around and used it with the old UC-A65 Rev. A board, which needs a reverse-type cable. That’s what was causing the short circuit and crashing the Pi 5.
With the correct cables, both revisions are now working perfectly:
UC-A65 Rev. A (old): Works on both RPi4 and RPi5 with a reverse (opposite-side) 22-to-22 pin cable.
UC-B47 Rev. A (new): Works on both RPi4 and RPi5 using either the included 15-to-22 pin cable or the included reverse 22-to-22 pin cable.
Lesson learned: check your cable orientation before you fry something!
Really glad you got it sorted and thanks for posting the detailed follow-up — this will definitely help others who run into the same confusion.
Just to summarize for anyone finding this thread in the future:
Identifying your revision:
Check the PCB silkscreen: UC-A65 Rev. A = old revision with 22-pin connector, UC-B47 Rev. A = new revision with 15-pin CSI connector.
Which cable to use:
UC-A65 Rev. A (old): Requires a reverse (opposite-side contacts) 22-to-22 pin cable. The original packaging only included a brown 15-to-21 pin cable, so you may need to source the reverse 22-to-22 separately.
UC-B47 Rev. A (new): Use either the included 15-to-22 pin cable or the included reverse 22-to-22 pin cable.
The key takeaway: Forward vs. reverse cable orientation is the critical distinction here. A forward (same-side) cable on the old UC-A65 Rev. A will short the Pi and trigger its protection shutdown. Both revisions work fine on RPi4 and RPi5 once the correct cable is used.
As for the 4-lane IMX708 driver issue mentioned at the start — that’s a separate limitation of the current Bookworm kernel and isn’t related to the cabling problem. The camera works in its default mode without any special driver installation.
