Multiple quad cam
    Arducam
    B0388
    Raspberry Pi
    None
  5. Problems you were having?
    Can I put 2 quad-cam hats on one pi5
  8. What help do you need?
    I want to look at putting two B0388 quad cam HATs on a single raspberry pi 5. However looking at the HAT it connects to some headers which I assume are for i2c to control the cameras. Is it possible to configure which ports these are and therefore allow me to connect 2 x B0388 quad cam HATs to each CSI port on the raspberry pi 5.
Hi there,
The Raspberry Pi 5 GPIO pins only power the HAT Kit, and there’s no I2C control on the headers.
Therefore, you can connect two B0388 quad-cam kits to the same Pi 5. You need to power the second Pi 5 with a single Type-C.
That’s great thanks - I note that the connector onto the HAT contains pins for 2 x 5V and 1x 3.3V plus the group. If I wanted to power the HAT via these connectors do I need to connect both the 5V and 3.3V or does the HAT just use one of the voltage lines and handle the conversion internally?
Cheers,
Neil
Hi there,
You only have to connect 5V and GND to power one of the HAT boards. No necessary to connect both 5V and 3V.
How do I set the config file so that I can detect a HAT on CAM0 and CAM1 please?
Cheers,
Neil
Hi there,
You can add the following lines to the configuration file.
dtoverlay=imx519
dtoverlay=imx519,cam0
Thanks - I put in a request to your sales department to ask for a minor modification (happy to pay for it) to allow me some way to set the focus differentially on the cameras. Lee may know me from my previous company, Ziath Ltd who he visited a few years ago - if we could follow that up I’d be grateful.
Thanks.
Regards,
Neil
:beers: :beers: :beers:
Let me know if you have any other problems.
