The Multi Camera Board V2.2 is working fine with standard V2 Raspberry Pi cameras on my Pi4. Unfortunately, I do get the missing “/dev/video0” error message, when I try it with the standard Raspberry Pi HQ camera (see below):
Each RaspHQcamera is working perfectly without the Multi_Camera_Adapter. And you can be sure, that I double-checked the orientation of the ribbon cable more than once.
I tested the RaspHQcameras together with the Multi_Camera_Adapter some weeks ago and everything worked perfectly.
What is wrong? I am desperate.
summary:
RaspHQcamera wo/ Multi_Camera_Adapter works
Rasp V2 camera w/ Multi_Camera_Adapter works
RaspHQcamera w/ Multi_Camera_Adapter does not work → /dev/video0 error message
thank you for your response. Did what you proposed. This is my error message:
pi@pi4wk1:~/RaspHQCamera/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_C++ $ ./init_camera.sh
----Test i2c1
00: – – – – – – – – – – – – –
10: – – – – – – – – – – 1a – – – – –
60: – – – – 64 – – – – – – – – – – –
70: 70 – – – – – – –
----Detecting the /dev/video0 device
video0 detected!
—Start testing each camera
if all of them are normal, after it finished,you will see four image in the current path.
Start testing the camera A
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn’t be enabled
mmal: Failed to run camera app. Please check for firmware updates
Start testing the camera B
Start testing the camera C
Start testing the camera D
There is only one camera attached to port D.
I am willing to re-install the Raspberry Pi OS if that helps? Although I do not know what happened between my success a few weeks ago and the issues I have now…
Thank you for your answer! I am really in need of your assistance.
The Pi has been rebooted always. I was asked by Lee to post pictures from my setup. Could you please check it? My setup uses two Raspberry HQ cameras on port C and port A. Do you recommend using different ports?
Please specify which port I should use if I have only one camera!
Please specify which ports I should use for two cameras!
Do I have to open all clamps of the unused ports? (I actually never thought about that.)
Which I2C-address should I expect (instead of 0x10) if I use two original RaspberryPi HQ cameras?
Don’t worry and I will try my best to help you. To facilitate our communication, you can add my skype ID: [email protected]
As normal, for the old firmware, you should connect the camera to the D port. For the new version firmware, you can connect the camera to any of the ports. So, you’d better to connect the camera to the D port to avoid your board’s firmware is the old.
