Hi @scruss
Sorry for the late reply…
I have make the multiplexer + imx708 work on Pi 5’s CAM 0 port, which should be same for CM4. I only connect one imx708 to Multiplexer, but it has no difference between one camera connected and four cameras connected.
Hardware connection
Hhhh, the CAM 1 port is broken and I do not know how to fix it
Software config
Add the entry below in the config.txt file:
I am having similar problems but with a Raspberry Pi 4, and I am curious if our problems are related.
In order to get your camera to work did you just have to add the ,cam0 to the end of the dtoverlay? Does the CM4 have multiple camera CSI ports like the Pi 5? Do you have all four ports on the camera connected to actual cameras?
Oh that is interesting about the Camera D = Camera 0. I just tried moving the camera, but no luck for me it still is not seeing a camera. Thanks for that tip though!
So in order for you to get it to work you just had to switch the physical camera port you were using on the CM4?
Since this topic was marked “solved” you’d be better off asking your own new question if you continue to have problems. Arducam staff may not monitor solved questions.
