Arducam Multi Camera Adapter module V2.2 for Raspberry Pi 4 (Arducam MIPI Compatible) EEP4215
Raspberry Pi 4B
online documentation, video tutorial
work intermittently
I have a Arducam Multi Camera Adapter module v2.2 using with Raspberry pi 4B with Python 2.7.16 version, OpenCV 4.5.0 and Numpy 1.16.2. I followed the documentation online and tutorial video. However, I need the python script because I have other things to control with the raspberry pi, but I cannot get the python scripts to work.
I did enable the raspi-config for I2C and camera, and also add (dtparam=i2c_vc=on) to the end line in sudo nano /boot/config.txt. I tested the sudo chmod +x init_camera.sh line for the files in the python folder and also tested AdapterTestDemo.py code working good but I can’t run and got error in PreviewOpencv.py programming .
Thank you.
