Multi-Camera Adapter - Jetson: GPIO 7, 11, 12 on Avermedia carrier board?
Hi, I need some help figuring out how the Multi-Camera Adapter - Jetson (B012001) actually works. I don’t have an error yet, I’m still trying to understand the wiring before I power anything up.
My setup:
  • Product: Arducam Multi-Camera Adapter - Jetson (B012001)
  • Target: Jetson Nano / Xavier NX
  • Carrier board: Avermedia carrier board (not the NVIDIA developer Xavier NX board)
The problem is that my carrier board has different GPIO names and positions compared to the Jetson developer board, so I can’t just follow the pictures that assume the dev board layout. I understand power is supposed to come through the CSI cable, is that correct?
Can someone confirm which pins/signals are actually required to switch between the cameras?
Hi, thanks for reaching out.
A quick note first: the B012001 was originally released for Raspberry Pi, so the instruction sheet that ships with some units is written for the RPi. That’s probably why the pin naming doesn’t line up with what you’re seeing.
For Jetson Nano / Xavier NX you should follow the Jetson-specific instructions here:
https://www.arducam.com/docs/camera-for-jetson-nano/multiple-cameras-on-the-jetson/arducam-multi-camera-adapter-on-the-nano-xavier-nx/
Have a read through that and let me know if anything is still unclear about the GPIO signaling.
Thanks, that page helps a bit but I’m still not 100% sure about the pins.
A few specific questions:
  1. Does it work with just 3 GPIO signals (LOW/HIGH)?
  2. Are the Multi-Camera Adapter - Jetson pins the ones shown in the picture I attached? I mean pin 7, pin 11 and pin 12.
  3. Do I only need to connect GPIO 7, 11 and 12, like in the picture?
My understanding is that I just need to drive some of those GPIO values LOW/HIGH in order to make the adapter switch cameras. There aren’t any other limitations we don’t know about, right?
Also, could you send me the instructions for Jetson Nano/Xavier NX specifically? The ones I got were clearly for Raspberry Pi.
Yes, that’s the basic idea — the adapter is controlled through the GPIO lines being driven LOW/HIGH, and it’s powered through the CSI cable, so you don’t need a separate power feed.
I’ve attached a picture that shows the pin/GPIO configuration for the Multi-Camera Adapter - Jetson. Please see the picture attached, I hope that will help.
For the full Jetson Nano/Xavier NX walkthrough, use this doc:
OK, looking at the picture now — so it really is just GPIO 7, 11 and 12, and I toggle them LOW/HIGH to select the camera. Power comes off the CSI cable, got it.
One last thing since my board is the Avermedia carrier board: the GPIO names/positions are different from the developer board. Do I just map the same signals to whatever the equivalent pins are on my board? I want to make sure I’m not missing some extra signal that only exists on the dev board.
Still no error to report yet, I just haven’t wired it up because I didn’t want to guess.
Right — since your Avermedia carrier board labels/positions the GPIOs differently from the NVIDIA developer board, you map the same three signals (the two control lines plus the ground reference) to the corresponding pins on your board. The adapter doesn’t need anything beyond those control GPIOs and the CSI connection, which is where it draws power.
So to summarize where we are:
  • The Multi-Camera Adapter - Jetson is controlled by driving the GPIO lines LOW/HIGH, and it’s powered through the CSI cable.
  • The pins to use are the ones shown in the attached picture (7, 11, 12).
  • For Jetson Nano/Xavier NX, follow the official doc here: Redirecting...
  • On your Avermedia carrier board, just map those same GPIO signals to your board’s equivalent pins since the naming/positions differ from the dev board.
Wire it up that way and let us know if you hit anything once you start testing the cameras.
