Multi-Camera Adapter Board Issue - Not Working
The Pi Hut
V2.2 https://thepihut.com/products/multi-camera-adapter-module-v2-2-for-raspberry-pi
Pi 4B with Rasbian
Have tried both https://www.arducam.com/docs/cameras-for-raspberry-pi/multi-camera-adapter-board/multi-camera-adapter-board-v2-1/ and https://github.com/ArduCAM/RaspberryPi/tree/master/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel
Never worked
Hello
I have not been able to get the adapter to work with with my 2 official raspberry Pi HQ cameras (plugged into (A and D)
I have started the OS from new, and followed the instructions from the links above. I have tested each camera and cables and I believe I have attached them all correctly
After successfully installing everything necessary in the guides I try to test and this is where I have issues. Below are the error messages I receive.
[email protected]:~ $ cd RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_C++/
[email protected]:~/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_C++ $ export DISPLAY=:0
[email protected]:~/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_C++ $ ./previewOpencv
Detected camera on channal:A
select timeout
select timeout
Camera is missing on channal:B
Camera is missing on channal:C
Detected camera on channal:D
select timeout
select timeout
Start preview…
select timeout
select timeout
select timeout
Segmentation fault
and also
[email protected]:~/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_C++ $ sudo chmod +x init_camera.sh
[email protected]:~/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_C++ $ sudo ./init_camera.sh
----Test i2c1
00: – – – – – – – – – – – – –
10: – – – – – – – – – – 1a – – – – –
60: – – – – 64 – – – – – – – – – – –
70: 70 – – – – – – –
----Detecting the /dev/video0 device
video0 detected!
—Start testing each camera
if all of them are normal, after it finished,you will see four image in the current path.
Start testing the camera A
Camera control callback cmd=0x4f525245mmal: No data received from sensor. Check all connections, including the Sunny one on the camera board
This is my 5th attempt at reformatting my microsd and starting from scratch and I still can’t find the fault
tested cameras and cables individually, plugged into A, B. C and D (keep it in D). Double checked interface config. Tried troubleshooting guides in forum.
If there is something obvious that you know of that im doing incorrectly, or if theres a way of running diagnostics to see if theres a hardware fault. Any advice would be welcome
Any update for your problem? I also received the same problem from the adapter.
No update and no solution found. I’ve opted to get around this by using a CM module and io board which has 2 camera ports. Its not ideal and it means I have to try to sell on these components but I just couldn’t find a way to solve it.
Good luck with your issues.
