Amazon
B016601
Raspberry Pi
paper instruction
work intermittently
There seems to be a delay between the completed write on GPIO 7 and the multiplexer switching to the “other” sensor, especially when you try to squeeze out more performance out of this hardware setup.
My questions are:
- What is the anticipated total time delay for the multiplexer hardware to switch completely to the “next” camera so that the next grab is taken entirely from the “other” sensor?
- Similar to the above, what is the maximum frame rate obtainable at the hardware level at the resolution you’re promoting (320x240, https://github.com/ArduCAM/RaspberryPi/blob/master/Multi_Camera_Adapter/Multi_Adapter_Board_2Channel_uc444/arducam_multi_adapter_uc444.cpp#L129-L130)
- Is there a way to read some GPIO or issue an I2C call to be able to know reliably when the next grab will happen from the intended sensor? I don’t know if it’s intentional, but in your example code you’re "grab"bing before doing a “read”: https://github.com/ArduCAM/RaspberryPi/blob/master/Multi_Camera_Adapter/Multi_Adapter_Board_2Channel_uc444/arducam_multi_adapter_uc444.cpp#L142-L143 which is redundant and introduces a slight, artificial delay.
In summary I’d like to know a way to programmatically tell that the next read from each sensor can be performed in full.
