I am trying to run a IMX477 purchased from Arducam, but when I try to use picamera2 module in Python I keep getting a warning:
WARN IPARPI ipa_base.cpp:817 Could not set AF_MODE - no AF algorithm
WARN IPARPI ipa_base.cpp:1441 Could not set LENS_POSITION - no AF algorithm
I am trying to run on a new Raspberry Pi 5:
uname -a
Linux raspberrypi 6.12.47+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1 (2025-09-16) aarch64 GNU/Linux
I have configured my /boot/firmware/config according to the guide here (I don’t use cam0, just dtoverlay=imx477,vcm):
https://docs.arducam.com/Raspberry-Pi-Camera/Motorized-Focus-Camera/Quick-Start-Guide/IMX477-Motorized-Focus-Camera/#hardware
And I set up the pivariety files with:
./install_pivariety_pkgs.sh -l
Which yields the following:
dpkg -l | grep libcamera
ii libcamera-apps 1.9.1-1 all transitional package
ii libcamera-dev 0.5.2+rpt20250909-2 arm64 complex camera support library (development files)
ii libcamera-ipa:arm64 0.5.2+rpt20250909-2 arm64 complex camera support library (IPA modules)
ii libcamera-tools 0.5.2+rpt20250903-1+b1 arm64 complex camera support library (tools)
ii libcamera-v4l2:arm64 0.5.2+rpt20250903-1+b1 arm64 complex camera support library (V4L2 module)
ii libcamera0.5:arm64 0.5.2+rpt20250909-2 arm64 complex camera support library
ii python3-libcamera 0.5.2+rpt20250903-1+b1 arm64 complex camera support library (Python bindings)
ii rpicam-apps 1.9.1-2 all Camera based applications for Raspberry Pi using the libcamera framework
ii rpicam-apps-core 1.9.1-2 arm64 Camera based applications for Raspberry Pi using the libcamera framework
I have tried a few variations of the following python file:
from libcamera import controls
import time
picam2 = Picamera2()
picam2.configure(picam2.create_still_configuration())
picam2.start()
picam2.set_controls({"AfMode" : controls.AfModeEnum.Manual})
picam2.set_controls({"LensPosition" : 10.0})
time.sleep(3)
picam2.capture_file("test.jpg")
picam2.stop()
picam2.close()
But I get that warning mentioned above. I don’t seem to get the error when running from rpicam-still:
rpicam-still --immediate --autofocus-mode manual --lens-position 5 --tuning-file /usr/share/libcamera/ipa/rpi/pisp/imx477_af.json -o mf_5.jpg
[0:01:10.497276202] [1355] INFO Camera camera_manager.cpp:330 libcamera v0.5.2+125-69c6546d-dirty (2025-10-10T01:59:59BST)
[0:01:10.511245091] [1360] INFO RPI pisp.cpp:720 libpisp version 1.3.0
[0:01:10.863836542] [1360] INFO IPAProxy ipa_proxy.cpp:180 Using tuning file /usr/share/libcamera/ipa/rpi/pisp/imx477_af.json
[0:01:10.882977035] [1360] INFO Camera camera_manager.cpp:220 Adding camera '/base/axi/pcie@1000120000/rp1/i2c@80000/imx477@1a' for pipeline handler rpi/pisp
[0:01:10.883007553] [1360] INFO RPI pisp.cpp:1180 Registered camera /base/axi/pcie@1000120000/rp1/i2c@80000/imx477@1a to CFE device /dev/media0 and ISP device /dev/media2 using PiSP variant BCM2712_D0
WARNING: Capture will not make use of temporal denoise
Consider using the --zsl option for best results, for example:
Made X/EGL preview window
Made DRM preview window
Preview window unavailable
Mode selection for 4056:3040:12:P
SRGGB10_CSI2P,1332x990/0 - Score: 10552.2
SRGGB12_CSI2P,2028x1080/0 - Score: 8179.84
SRGGB12_CSI2P,2028x1520/0 - Score: 7096
SRGGB12_CSI2P,4056x3040/0 - Score: 0
Stream configuration adjusted
[0:01:11.087379978] [1355] INFO Camera camera.cpp:1215 configuring streams: (0) 4056x3040-YUV420/sYCC (1) 4056x3040-BGGR_PISP_COMP1/RAW
[0:01:11.087518272] [1360] INFO RPI pisp.cpp:1484 Sensor: /base/axi/pcie@1000120000/rp1/i2c@80000/imx477@1a - Selected sensor format: 4056x3040-SBGGR12_1X12/RAW - Selected CFE format: 4056x3040-PC1B/RAW
Still capture image received
And from what I can tell when I change the --lens-position value the focus is obviously changing. So I am not sure if something has changed in the Python syntax for the motorized version or if I am just doing something wrong with the deps/config?
Any help would be greatly appreciated.
-Raymond
