Hi everyone, hoping someone can point me in the right direction. I have an Arducam camera on my OctoPrint setup and the video feed shows up fine, but the motorized focus doesn’t work at all. Just to be clear, I’m talking about the motorized focus, not auto focus. The image is coming through, I just can’t move the focus at all.
Thanks for the report. Could you share a bit more about your setup? Specifically which Arducam model you’re using and what board/OS you’re running OctoPrint on.
Sure. It’s the Arducam 5MP OV5647 with motorized focus, running on a Raspberry Pi 3B+ with OctoPi. I followed the instructions on the ArducamCameraControl plugin page here: ArducamCameraControl
Got it. So after following the setup steps on that plugin page, what exactly happens in the OctoPrint UI? Do the controls appear at all, or are they unresponsive?
The controls show up in the plugin, but every Arducam option is greyed out. I can’t click anything related to focus or the camera controls. The video preview still works though, which is the confusing part.
That’s a useful clue actually. If video is working, the sensor and the ribbon connection are probably fine. Greyed out options usually mean the plugin isn’t getting a proper response from the motorized focus side of things. Do you happen to have any logs from OctoPrint or the plugin you could share?
Sorry, I don’t have any logs right now. I didn’t grab them before posting. If you tell me where to look I can try to pull them.
No problem. Just for now, can you check the OctoPrint logs section (Settings > Logs) after you open the plugin tab? That may show errors from the plugin while it tries to initialize the focus controls. But before you dig too deep, let me summarize what we know: your OV5647 is outputting video correctly, but the motorized focus doesn’t respond and every Arducam option is greyed out. That points more toward a plugin/control integration issue than a dead camera sensor. I need to check the auto-focus plugin side of things on our end, and I’ll follow up within two working days.
Thanks, that makes sense. I’ll grab those logs in the meantime and post back if I see anything odd. I’ll wait for your update on the plugin.
Sounds good. To recap the current state: root cause isn’t pinned down yet, but video works while motorized focus fails and all Arducam plugin options are greyed out, so we’re investigating the auto-focus/plugin control integration. I’ll follow up once I’ve had a chance to dig into the plugin on our side. In the meantime, if you can share those OctoPrint logs it would help narrow things down faster.
