UCTRONICS
Camarray – Arducam 2MP*2 Stereo Camera MIPI Module
Raspberry PI 4B 8GB
yes
I’m using the 2MP OV2311 stereo camera module with kernel 5.4.79 and the arducam/bcm2835-unicam modules. Based on the arducamstill code I’m able to retrieve the video data, which works quite well (very low cpu load). However, I was wondering if it is also possible to also get the metadata for a frame.
It looks like bcm2835-unicam is already able to retrieve metadata for other sensors. I’ve tried to add the metadata pad in arducam.c/.ko, but I don’t seem to get any metadata via v4l2.
Can you provide a driver which supports retrieving metadata?
