Mechanical Drawing for B0445
    Purchased directly from Arducam.
    B0445 (1.58MP IMX296 Color Global Shutter Camera Module with M12 Lens for Raspberry Pi)
    Raspberry Pi 5, Bookworm OS, dtoverlay=imx296. The cameras run fine; this is purely a mechanical integration question.
    I checked the following and could not find a mechanical drawing:
The only dimensional data I can find is “Camera Board Size 38 x 38 mm” and “13 mm lens holder height”.
  1. Request
    Could you provide a 2D mechanical drawing and, if available, a STEP file for B0445? I am designing a custom mounting bracket to integrate these modules into a robot platform, and I need the following:
  • Board outline with tolerances
  • Mounting hole positions (hole-to-hole pitch in X and Y) and hole diameter
  • Total Z height from PCB bottom surface to the front face of the M12 lens holder, and PCB thickness
  • Lens holder outer diameter and its position relative to the board outline
  • Keep-out / clearance around the 22-pin FPC connector on the back side
