I just received my EK036 evaluation kit for Windows 11. I installed everything successfully, but I need the config files for this SKU. Can someone provide them? Also, where exactly should I copy the config files once I get them?
Thanks for reaching out! I’ll have the config files for EK036 sent over to your email shortly. Once you receive them, you can place the .cfg files into the SensorDetect folder within your Arducam installation directory.
I received the files from Jessie at [email protected]. I copied both .cfg files into the SensorDetect folder, but now I’m getting an error message: “It’s a wrong parameter in the delivered config file!” I’ve attached a screenshot of the error. What’s going on here?
I’ve been brought in to take a look at the config file issue with your EK036. Before we dig into the config files themselves, could you try a different approach? Instead of placing the .cfg files in the SensorDetect folder, try loading them directly through the Arducam GUI. You can follow this guide: Windows Graphical User Interface(GUI) - Arducam Wiki . Let me know what happens.
Okay, I removed the .cfg files from the SensorDetect folder and loaded them through the GUI as you described. But now I’m getting a USB timeout error when I try to change the USB connection. I’ve attached a screenshot of the error. Any idea what’s wrong?
Interesting - could you check if both config files behave the same way? Try the 640x480 .cfg file and the 1600x1400 .cfg file separately and let me know which ones work and which don’t.
So the 640x480 .cfg file works fine, but the 1600x1400 one still gives USB timeout errors. My laptop is an Intel Core Ultra 7 155H - I’ve attached a screenshot of my USB configuration.
Thanks for the pictures. Please completely uninstall the software, remove the USB driver, and delete any leftover Arducam files from your system. Then do a fresh install from scratch. Let me know how it goes.
Alright, I deinstalled everything, deleted all Arducam files, and did a fresh install. Now the evaluation kit is working! Both config files load without errors and the camera is functioning. One thing though - the lens focus point wasn’t set optimally from the factory, so the pictures were coming out blurry. I swapped the lens to a 6mm non-distortion IR lens and that sorted it out.
Great news that the clean install resolved the software issues! That “wrong parameter” error and the USB timeout were likely caused by leftover configuration conflicts from the initial setup. As for the lens focus - that’s good feedback. The EK036 ships with a standard lens, and depending on your use case, swapping to a 6mm non-distortion IR lens makes sense if you need sharper images with less barrel distortion. Glad everything’s working now!
I have the same problem with Chris001, may I have the config files for EK036 as well, I tried to email [email protected] but still haven’t received anything yet
Hi @nontk
Our sales team will reply to you along with the config file within two working days. Thanks for your patience.
