Amazon -
Any model of ArduCAM UVC Webcam -
Raspberry Pi running Raspbian Linux -
Amcap.exe on Windows. -
Need to set the h264 bitrate control using a Linux utility, similar to Amcap.exe on Windows. -
Looked for 3rd party method of setting h264 bitrate control on Linux. My search yielded nothing. -
Please tell me a method to set the h264 encoder bitrate control using a Linux utility, on the Arducam, not in a later pipeline. Is there a Linux utility or a way to set registers in Linux for a USB UVC webcam to adjust the h264 encoder bitrate on the Arducam itself? You can do this using a Windows utility from ArduCam called AmCap.exe. However, I am needing a Linux program or shell commands to do the same.
@jhassell
The rate control protocol is a custom protocol through the XU channel, which cannot directly use ordinary amcap, and needs to customize a special SDK.
Does Arducam offer a way for Linux users to use this custom protocol? Can the XU channel possibly be accessed through a Linux terminal in some way?
Alternatively, can the H264 Preview 1.1.6.3.zip Windows program save the H264 bitrate control setting to non-volatile memory? I just need the H264 bitrate value set to 500kbps, on the Arducam itself, and have that setting survive a power cycle.
See: H264 Preview 1.1.6.3.zip
If you have needs in this area, you can fill in the form for further needs. The reason for this is to understand why you need this functionality and make an assessment.
I have the same issue, I need to limit the camera bitrate, I tried using the uvch264src plugin with gstreamer, but had no luck with it.
For any users seeking clarification or assistance, I kindly invite you to click on the link provided above, which will grant you access to comprehensive support and guidance.
