DigiKey -
ARDUCAM MEGA 3MP SPI -
Arduino UNO -
Getting Started with Arducam Mega -
limited SRAM on Arduino UNO -
When compiling the example “capture2SD” in the examples directory of the Arducam_Mega library, in the Arduino IDE 2.1.1, the output indicates that the application uses 78% (=1613 bytes) of the dynamic memory. Leaving only 22% of SRAM will cause problems in most applications using Arduino UNO, Arducam Mega and SD card. Librarys SD.h and Arducam_Mega.h use most of the SRAM. Is there a way to significantly reduce SRAM usage in these libraries or can Arducam_Mega not really be used with Arduino UNO and SD card?
