Problems you were having? libcamera-vid ... -o test.h264 hangs
The dmesg log from your hardware? – I can post the full log, there are no unusual error messages. And:
$ dmesg|head
[ 0.000000] Linux version 5.10.60-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1449 SMP Wed Aug 25 15:00:01 BST 2021
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model A Plus Rev 1.0
[ 0.000000] Reserved memory: created CMA memory pool at 0x07c00000, size 256 MiB
$ dmesg|egrep arducam
[ 8.393648] arducam: loading out-of-tree module taints kernel.
[ 8.410354] arducam-pivariety 10-000c: firmware version: 0x10002
[ 33.754466] arducam_vddl: disabling
[ 33.754486] arducam_vdig: disabling
[ 33.754507] arducam_vana: disabling
Troubleshooting attempts you’ve made? see below
What help do you need? Information on how to make it work’
I’m using the arducam imx462 low light camera and cannot get h264 to work. I installed everything per instructions (multiple times). The one thing that I have different from the instructions is that after an apt upgrade I now have the latest kernel. But I have reinstalled the arducam kernel driver after upgrading the kernel.
$ uname -a
Linux rpi-cam2 5.10.60-v7+ #1449 SMP Wed Aug 25 15:00:01 BST 2021 armv7l GNU/Linux
What happens is the following (taken from the instructions) hangs:
$ libcamera-vid -t 10000 --width 1920 --height 1080 -n -v -o test.h264
Options:
verbose: 1
info_text:#%frame (%fps fps) exp %exp ag %ag dg %dg
timeout: 10000
width: 1920
height: 1080
output: test.h264
rawfull: 0
preview: none
transform: identity
roi: all
metering: centre
exposure: normal
ev: 0
awb: auto
flush: false
wrap: 0
brightness: 0
contrast: 1
saturation: 1
sharpness: 1
framerate: 30
denoise: auto
viewfinder-width: 0
viewfinder-height: 0
bitrate: 0
profile:
level:
intra: 0
inline: 0
save-pts:
codec: h264
quality (for MJPEG): 50
keypress: 0
signal: 0
initial: record
split: 0
segment: 0
circular: 0
Opened H264Encoder on /dev/video11 as fd 3
Got 6 output buffers
Got 12 capture buffers
Codec streaming started
Running without preview window
Opening camera...
[2:54:55.418254864] [1041] INFO Camera camera_manager.cpp:296 libcamera v0.0.0+2736-579f55b1-dirty
(2021-07-01T03:47:30-04:00)
[2:54:55.433443946] [1046] WARN CameraSensor camera_sensor.cpp:197 'arducam-pivariety 10-000c': Rec
ommended V4L2 control 0x009a0922 not supported
[2:54:55.447397721] [1046] WARN CameraSensor camera_sensor.cpp:249 'arducam-pivariety 10-000c': The
sensor kernel driver needs to be fixed
[2:54:55.447499856] [1046] WARN CameraSensor camera_sensor.cpp:251 'arducam-pivariety 10-000c': See
Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[2:54:55.454658566] [1046] WARN CameraSensorProperties camera_sensor_properties.cpp:109 No static p
roperties available for 'arducam-pivariety'
[2:54:55.454788305] [1046] WARN CameraSensorProperties camera_sensor_properties.cpp:111 Please cons
ider updating the camera sensor properties database
[2:54:55.454876273] [1046] WARN CameraSensor camera_sensor.cpp:403 'arducam-pivariety 10-000c': Fai
led to retrieve the camera location
[2:54:55.695713045] [1046] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety.js
on' not found for IPA module 'raspberrypi'
[2:54:56.115404801] [1046] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control i
d 0x009a090a but control is not exposed by device /dev/video0
Acquired camera /base/soc/i2c0mux/i2c@1/arducam@0c
Configuring video...
[2:54:56.124474698] [1041] WARN V4L2 v4l2_pixelformat.cpp:181 Unsupported V4L2 pixel format XB24
[2:54:56.126173491] [1041] INFO Camera camera.cpp:906 configuring streams: (0) 1920x1080-YUV420
[2:54:56.127162235] [1046] INFO RPI raspberrypi.cpp:128 Mode: 1920x1080 fmt RG10 Score: 1500 (best
1500)
[2:54:56.127328797] [1046] INFO RPI raspberrypi.cpp:128 Mode: 1920x1080 fmt pRAA Score: 1000 (best
1000)
[2:54:56.194027849] [1046] INFO RPI raspberrypi.cpp:625 Sensor: /base/soc/i2c0mux/i2c@1/arducam@0c
- Selected mode: 1920x1080-pRAA
Camera streams configured
Buffers allocated and mapped
Video setup complete
Requests created
[2:54:56.331913012] [1050] INFO IPARPI raspberrypi.cpp:637 Request ctrl: Sharpness = 1.000000
[2:54:56.332288739] [1050] INFO IPARPI raspberrypi.cpp:637 Request ctrl: Saturation = 1.000000
[2:54:56.332438634] [1050] INFO IPARPI raspberrypi.cpp:637 Request ctrl: Contrast = 1.000000
[2:54:56.332596862] [1050] INFO IPARPI raspberrypi.cpp:637 Request ctrl: Brightness = 0.000000
[2:54:56.332724726] [1050] INFO IPARPI raspberrypi.cpp:637 Request ctrl: FrameDurationLimits = [ 33
333, 33333 ]
[2:54:56.332984985] [1050] INFO IPARPI raspberrypi.cpp:637 Request ctrl: NoiseReductionMode = 1
[2:54:56.333302067] [1050] INFO IPARPI raspberrypi.cpp:637 Request ctrl: AeMeteringMode = 0
[2:54:56.333698314] [1050] INFO IPARPI raspberrypi.cpp:637 Request ctrl: AeExposureMode = 0
[2:54:56.333874095] [1050] INFO IPARPI raspberrypi.cpp:637 Request ctrl: ExposureValue = 0.000000
[2:54:56.334065343] [1050] INFO IPARPI raspberrypi.cpp:637 Request ctrl: AwbMode = 0
[2:54:56.343128522] [1046] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[2:54:56.343304354] [1046] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
Camera started!
After that… nothing…forever… And the output file test.h264 remains empty.
I tried producing mjpeg instead and that works:
$ libcamera-vid -t 10000 --width 1920 --height 1080 --codec mjpeg -n -v -o test.mjpeg
[... lots of line omitted ...]
[2:49:43.503900436] [985] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (1
left)
[2:49:43.530779400] [985] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (0
left)
Viewfinder frame 0
Viewfinder frame 1
Viewfinder frame 2
Viewfinder frame 3
Viewfinder frame 4
Viewfinder frame 5
FileOutput: opened output file test.mjpeg
FileOutput: output buffer 0x732df008 size 96449
FileOutput: output buffer 0x7329e008 size 165940
Viewfinder frame 6
FileOutput: output buffer 0x727243d8 size 99164
[... etc etc]
Aha, so 1280x720 doesn’t work either, but 640x480 does work. Libcamera uses the same full-frame src, it seems:
[8:17:45.554113609] [1403] WARN V4L2 v4l2_pixelformat.cpp:181 Unsupported V4L2 pixel format XB24
[8:17:45.555798962] [1403] INFO Camera camera.cpp:906 configuring streams: (0) 640x480-YUV420
[8:17:45.556837184] [1408] INFO RPI raspberrypi.cpp:128 Mode: 1920x1080 fmt RG10 Score: 2136.67 (be
st 2136.67)
[8:17:45.557063849] [1408] INFO RPI raspberrypi.cpp:128 Mode: 1920x1080 fmt pRAA Score: 1636.67 (be
st 1636.67)
[8:17:45.626653161] [1408] INFO RPI raspberrypi.cpp:625 Sensor: /base/soc/i2c0mux/i2c@1/arducam@0c
but then it actually does process frames:
Camera started!
[8:17:46.147852648] [1408] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (7 left)
[8:17:46.173763251] [1408] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (6 left)
[8:17:46.201737902] [1408] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (
5 left)
[8:17:46.226070183] [1408] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (4 left)
[8:17:46.251561414] [1408] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (3 left)
[8:17:46.276058797] [1408] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (2 left)
[8:17:46.300838835] [1408] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (1 left)
[8:17:46.326424128] [1408] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (0 left)
Viewfinder frame 0
FileOutput: opened output file test.h264
FileOutput: output buffer 0x75487000 size 18974
Viewfinder frame 1
FileOutput: output buffer 0x75407000 size 13562
Viewfinder frame 2
FileOutput: output buffer 0x75387000 size 7745
Viewfinder frame 3
FileOutput: output buffer 0x75307000 size 18700
etc...
1024x768 works as well…
This is what I have in terms of reserved memory:
$ egrep mem /boot/config.txt
gpu_mem=128
$ dmesg|egrep cma
[ 0.000000] Memory: 109728K/393216K available (10240K kernel code, 1312K rwdata, 2948K rodata, 1024K init, 863K bss, 21344K reserved, 262144K cma-reserved)
[ 6.816200] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.822058] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
It’s strange, it doesn’t have any related error logs.
Is there any related output in the complete dmesg log?
If not, I think I need to perform some tests.
Some progress. I had forgotten the 3A+ only has 512MB memory, so I tweaked the config.txt to reduce gpu_mem to 64MB and disable framebuffers. Now 1280x1024 works and 1920x1080 sometimes works and sometimes doesn’t. Here’s top (it doesn’t look different when it works vs. doesn’t):
top - 20:35:13 up 11 min, 3 users, load average: 0.08, 0.06, 0.01
Tasks: 115 total, 1 running, 114 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.0 us, 0.2 sy, 0.0 ni, 99.8 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 427.6 total, 176.0 free, 105.4 used, 146.1 buff/cache
MiB Swap: 100.0 total, 100.0 free, 0.0 used. 269.6 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
733 tve 20 0 108588 13872 12724 S 0.0 3.2 0:00.47 libcamera-vid
Do you have any suggestions for figuring out what specifically is failing?
Dmesg shows no error. Syslog shows no error. Gstream shows no unusual error (just all the noise from libcamera). So the gstreamer output ends with
[0:06:40.467781955] [680] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (2 left)
[0:06:40.506089521] [680] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (1 left)
[0:06:40.539310783] [680] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (0 left)
Use the following command to make it output normally, but the output h264 file is not correct, even if I use videotestsrc it is the same, this may be a problem with the encoding component.
In your first example (gst-launch-1.0 -v libcamerasrc ! video/x-raw,format=NV21,width=640,height=480 ! videoconvert ! tee ! v4l2h264enc !…) you use videoconvert, which means software processing of the image stream. THat doesn’t really work… (Maybe for 640x480, but that’s not the goal here, I’m just using that video size to avoid hitting obscure memory issues while I’m trying to get a HW pipeline to work.)
Your second example also uses videoconvert and must be similarly slow as molasses…
Unfortunately, I cannot find 3A+ for testing temporarily, but you should not need to set gpu_mem, you can try to comment out start_x=1 and gpu_mem=xxx.
I have a Pi 3B here and it’s not working any better. The last examples I posted were from the 3B… Can you show a commandline that produces h264 all in HW with gstreamer on the 3B?
So I did a bunch more testing… and it turns out I have a bad camera.
I had purchased two imx462 cameras (from uctronics) and had both assembled. Then, unbeknownst to me, depending on which camera I happened to connect to the rPi in the morning things would work or not. So on friday I was lucky and connected the good camera and got libcamera-vid piped into gst-launch to work nicely. I then proceeded to configure a second identical rPi for the other camera and I just couldn’t get it to work. I thought I installed the software incorrectly, and spent hours troubleshooting, etc, etc.
Today I finally swapped cameras between the rPis and discovered that one camera works and the other doesn’t. Then I stripped everything down and swapped one part at a time: power supply, SFC cables, adapter board, etc). The bottom line is that one of the UC-755 camera boards works and the other doesn’t. The camera initializes fine, libcamera-still -t 5000 -o test.jpg works, but libcamera-vid at full resolution just hangs there and never produces data. Specifically:
$ libcamera-vid -t 0000 --width 1920 --height 1080 --framerate 5 -n --codec h264 --pro
file high --intra 20 -o test.h264
[0:01:11.789053510] [723] INFO Camera camera_manager.cpp:296 libcamera v0.0.0+2736-579f55b1-dirty (2021-07-01T03:47:30-04:00)
[0:01:12.588632181] [727] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:01:12.588727029] [727] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[...libcamera-vid hangs here...]
With the good camera, the output continues with:
[0:00:31.139760820] [560] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (7
left)
[0:00:31.165444934] [560] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (6
left)
[etc.]
I suppose I need to go through uctronics to get the bad camera replaced?
Sorry for your bad manager,
Can you take a detailed photo of a non-working UC-755?
All modules should be tested before they leave the factory, and we want to confirm whether there is any obvious damage on the modules.
