Hi everyone. I’m trying to use the Arducam Multi Camera Adapter Doubleplexer Stereo Module V2 with a Raspberry Pi 4 so I can run 2 cameras at the same time. The problem is I get a libcamera library error whenever I try to integrate the cameras. I already tried the information that came in the pamphlet, but it didn’t help.
Thanks for the details. Could you tell us a bit more about your setup — which Raspberry Pi model, the adapter board, and how many cameras you have connected? Also, any error text or logs you can paste would really help narrow this down.
For this board, the relevant guide is the dual camera adapter board section of the Arducam Multi-Adapter Board docs (board B016601). Have you had a chance to review it yet?
It’s a Raspberry Pi 4 with the Arducam Multi Camera Adapter Doubleplexer Stereo Module V2 and 2 cameras. I don’t have any code or logs to share right now — the error just shows up as a libcamera library error. I did go through the Quick Start Guide for the Multi Adapter Board link you mentioned, but I’m really looking for a more detailed manual to integrate the adapter with the Pi 4. I’m still stuck.
Thanks for confirming. Without the exact error output it’s a bit harder to pin down, but the first thing we need to figure out is which exact camera model is connected to the Multi Camera Adapter Doubleplexer Stereo Module V2. The libcamera error can come from a few different places depending on the sensor/model, so we need that camera model identified before we can go any further with troubleshooting.
