Libcamera_cpp_demo-master
In CMakeLists.txt the following sb added:
# specify the C++ standard
set(CMAKE_CXX_STANDARD 17)
set(CMAKE_CXX_STANDARD_REQUIRED True)
In LibCamera.cpp
plane.fd.fd() should be replaced with plane.fd.get()
It should now compile but will yield the following error at runtime:
[20:19:27.955246663] [30733]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3416-179ef58c
[20:19:27.972776273] [30734]  WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for 'arducam-pivariety'
[20:19:27.972825087] [30734]  WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database
[20:19:27.972852401] [30734] ERROR CameraSensor camera_sensor.cpp:551 'arducam-pivariety 10-000c': Camera sensor does not support test pattern modes.
[20:19:27.989996703] [30734] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety.json' not found for IPA module 'raspberrypi'
[20:19:28.345539571] [30734]  WARN RPI raspberrypi.cpp:1233 Mismatch between Unicam and CamHelper for embedded data usage!
[20:19:28.346032284] [30734] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[20:19:28.346184985] [30734]  INFO RPI raspberrypi.cpp:1356 Registered camera /base/soc/i2c0mux/i2c@1/arducam@0c to Unicam device /dev/media0 and ISP device /dev/media3
[20:19:28.346875714] [30733]  INFO Camera camera.cpp:1028 configuring streams: (0) 640x480-RGB888
[20:19:28.376368534] [30734]  INFO RPI raspberrypi.cpp:751 Sensor: /base/soc/i2c0mux/i2c@1/arducam@0c - Selected sensor format: 1920x1080-SRGGB10_1X10 - Selected unicam format: 1920x1080-pRAA
[20:19:28.397386118] [30737]  INFO IPARPI raspberrypi.cpp:666 Request ctrl: FrameDurationLimits = [ 33333, 33333 ]
Unable to init server: Could not connect: Connection refused
terminate called after throwing an instance of 'cv::Exception'
  what():  OpenCV(4.5.5) /home/pi/opencv/modules/highgui/src/window_gtk.cpp:635: error: (-2:Unspecified error) Can't initialize GTK backend in function 'cvInitSystem'
Aborted
