user resetCamera to decrease resolution to 1280x720
capture image and observe it was captured
use resetCamera to increase resolution to 3840x2160
observe that application is unable to read frame and gets stuck
My modified code to illustrate this
I ran several resolution change scenarios and concluded that the problem is only when next resolution is equal or larger than previous:
1280x720->1280x720=fail
4624x3472->1280x720=success
1280x720->3840x2160=fail
4624x3472->3840x2160=success
1280x720->4624x3472=fail
There is indeed a problem of switching resolutions stuck at the minimum resolution. I’m sorry for that. There are some problems with the minimum resolution configuration of the camera. We have fixed the relevant problems and will release the latest driver in the latest version and the next version of the kernel.
You can try 3840x2160 → 4624x3472
This is fine. I dont really need the 1280x720 anyways. I thought the bug happens all the time when switching to lower res, i see its only the lowest res now thats the problem. I should have done more testing in the first place.
It is completely correct, only the configuration of one line of registers caused this situation, it will not affect the camera output, but there will be problems when switching resolutions. This problem has been fixed in the latest version. Don’t worry at all.
