I get
sudo git clone https://github.com/ArduCAM/RaspberryPi.git
… made what suggested in RaspberryPi/Motorized_Focus_Camera/README.md
in RaspberryPi/Motorized_Focus_Camera/python run: python3 -m pip install ./libcamera-1.0.2-cp39-cp39-linux_armv7l.whl libcamera-1.0.2-cp39-cp39-linux_armv7l.whl is not a supported wheel on this platform.
same error python3 -m pip install ./libcamera-1.0.1-cp39-cp39-linux_armv7l.whl libcamera-1.0.1-cp39-cp39-linux_armv7l.whl is not a supported wheel on this platform.
uname -a
Linux Display20 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
Use the following command to check the python version:
python3 -V
For the difference between system versions and the installation of the corresponding libcamera python library, please refer to the following instructions:
My python is 3.7
Hardware Revision: a02082
Kernel Version: 5.10.103-v7+
OS Codename: buster
ARCH: armv7l
I get libcamera-1.0.1-cp37-cp37m-linux_armv7l.whl r=cam.initCamera(640,480,libcamera.PixelFormat.RGB888, buffercount=4, rotation=0)
result: [19:27:49.632882344] [1958] WARN IPAManager ipa_manager.cpp:149 No IPA found in ‘/usr/local/lib/arm-linux-gnueabihf/libcamera’ [19:27:49.633456976] [1958] INFO Camera camera_manager.cpp:293 libcamera v0.0.0
Another test with libcamera-still: libcamera-still -t 5000 -o test.jpg
[20:24:03.788379024] [9318] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3139-5baab39e
Aborted
You will also need to install our camera driver and the libcamera deb package we made.
The link below can be used as a reference for installing the driver. You also need to install the corresponding camera driver according to your camera type:
You can refer to the link below to install and use libcamera.
uname -a Linux Display20 5.15.32-v7+ #1538 SMP Thu Mar 31 19:38:48 BST 2022 armv7l GNU/Linux
python3 -V Python 3.9.2
cat /boot/config.txt
[cm4]
otg_mode=1
# arducam https://www.arducam.com/docs/cameras-for-raspberry-pi/raspberry-pi-libcamera-guide/
dtoverlay=imx519
dtoverlay=imx519,cam0
___________________Errors: dmesg
imx519 10-001a: failed to read chip id 519, with error -5
imx519: probe of 10-001a failed with error -5
Is this error about software or hadware error?
raspistill --verbose
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
libcamera-still -v
Made X/EGL preview window
Opening camera...
[1:39:07.100137140] [14401] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
Closing Libcamera application(frames displayed 0, dropped 0)
Camera stopped!
Tearing down requests, buffers and configuration
Camera closed
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=85
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=off
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
#otg_mode=1
#dtoverlay=imx519
#dtoverlay=imx519,cam0
[pi4]
arm_boost=1
dtoverlay=arducam
gpu_mem=128
I was wondering if the solution you suggested above will also work with the following specifications
Error log:
[email protected]:~ $ libcamera-still -t 5000 -o test.jpg
[0:02:45.442544575] [1006] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3139-5baab39e
Aborted
