Arducam IMX477 Autofocus and Software-Controlled Focus HQ Camera, 12MP 100° FOV Camera Module Compatible with Nvidia Jetson Nano/Xavier NX and NVIDIA Orin NX/AGX Orin, M12 Lens
Waveshare IMX219-160IR Camera for Jetson Nano Infrared Night Vision 3280 × 2464 Resolution 8 Megapixels 160° FOV IMX219 Sensor Suit for Face Recognition Road Mark Detection License Plate Recognition
Yahboom Jetson Nano Developer Kit Nano B01 with 16G-eMMC Based on Official N-VI-Dia Jetson Nano 4GB Core Module
Jetson Nano B01
NVIDIA forum and google
I need to get the IMX477 working along with the IMX219. The IMX219 works but when I try to use the IMX477, the Jetson nano crashes. Please help. Thank you.
I am not using a command. I am using a script I found on github. There is no error. The Jetson nano just crashes. I will give the script bellow.
MIT License
Copyright (c) 2019-2022 JetsonHacks
Using a CSI camera (such as the Raspberry Pi Version 2) connected to a
NVIDIA Jetson Nano Developer Kit using OpenCV
Drivers for the camera and OpenCV are included in the base image
import cv2
gstreamer_pipeline returns a GStreamer pipeline for capturing from the CSI camera
Flip the image by setting the flip_method (most common values: 0 and 2)
display_width and display_height determine the size of each camera pane in the window on the screen
Default 1920x1080 displayd in a 1/4 size window
# To flip the image, modify the flip_method parameter (0 and 2 are the most common)
print(gstreamer_pipeline(flip_method=0))
video_capture = cv2.VideoCapture(gstreamer_pipeline(flip_method=0), cv2.CAP_GSTREAMER)
if video_capture.isOpened():
try:
window_handle = cv2.namedWindow(window_title, cv2.WINDOW_AUTOSIZE)
while True:
ret_val, frame = video_capture.read()
# Check to see if the user closed the window
# Under GTK+ (Jetson Default), WND_PROP_VISIBLE does not work correctly. Under Qt it does
# GTK - Substitute WND_PROP_AUTOSIZE to detect if window has been closed by user
if cv2.getWindowProperty(window_title, cv2.WND_PROP_AUTOSIZE) >= 0:
cv2.imshow(window_title, frame)
else:
break
keyCode = cv2.waitKey(10) & 0xFF
# Stop the program on the ESC key or 'q'
if keyCode == 27 or keyCode == ord('q'):
break
finally:
video_capture.release()
cv2.destroyAllWindows()
else:
print("Error: Unable to open camera")
